Drill set
Gestart door Rogal118
6 replies 9 vind ik leuks Laatste activiteit: 5 jaren geleden
Drill set
Hi guys, Shout out to Rogal 118 picked up quite a few bits and pieces from Lidls Glue, drills and some dremel bits.
cheers mate, Jim.
Drill set
Watch the Parkside web site, I Checked on Tuesday and they were not there then, so unless someone nearer you can go to a Lidl store at present that's your 2 options.
Drill set
Went shopping yesterday and bought the same, but had to take it back today as drills and pin chuck missing. None left in shop so got a refund. Next nearest is 63 miles away.
Does anyone else stock them.
Drill set
Yes it made me think. Look on the top edge in the centre is like 2 arrows with the points just touching each other, one arrow is on the case back the other on the front. So between your thumb and forefinger twist the points past each other. A bit like the clasps on your mams purse.hope this is clear, let me know please how you get on
Roger.👍
Roger
Drill set
I guess I'm plain thick, with ref to the box's of drills, how the heck do you open the 2 plastic box's, I was able to open the cardboard box with no problens.....😂😂😂😂😊😊🤔
Geliked door MouldBuilder and Rogal118
Drill set
Might be of interest to some of you guys, just picked up this set of drill bits and small vice and also pin vice with 3 piece chuck. .5mm up to 3mm. I've found you can't have enough small bits.these are from the "middle" of a well known rhyming supermarket £ 7.99. Not for heavy engineering but ideal for model boat building.
Roger
Geliked door Northernflotsam and Mike Stoney and
