Vosper 46ft RAF crash tender
If you decide to go for a permanently fitted shaft greasing tube you can buy them online and they are easy to install.
Hopefully the link below will work
https://www.ebay.co.uk/itm/203504999935?var=0&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338268676&toolid=10044&customid=CjwKCAjw4ayUBhA4EiwATWyBrrKzuB_JpMMF22ER9P3XoKMvSPfomit4gmA3fU0c8dspVZEtUF0roRoCkUsQAvD_BwE
Thanks
If the former, you need to do nothing. Oilite bearings/bushings are self lubricating. If the latter, then either greasing or oiling the tube is advised. This can be done by periodically pulling the shaft and lubricating it, or... soldering an oil/grease tube to the shaft log. Then you can add a piece of silicon tubing and periodically add oil or grease.
Geliked door
Bezig met laden…
