JOHN HEMMENS LADY JANE
Volgers (2)
- NickthesteamSilver
With reference to pipes being blocked, all except for the internal pipes in the boiler have been removed or replaced.
I have to agree with Nickthesteam on his comments re your boiler and engine.
Steam plants do need regular maintenance and if in a similar condition to the Lady Jane there is a real possibility that most of the pipes will be blocked and need dismantling and cleaning. The boiler is likely to be heavily scaled inside and you should not attempt to steam it until it has been checked and cleaned and then water Pressure tested by a registered boiler tester. For your own safety please do not attempt to steam the boiler until this safety test has been completed. The fact that the water tank was full of solidified gunk suggests the previous owner was not cleaning down after use. The Hemmens units are well made and usually perform very well if used as designed.
Hope you can resolve all the issues and get the unit into working condition.
Geliked door
Bezig met laden…
