Boat Show
Boat Show
Cheers, Nerys
Boat Show
Can't believe I produced these drawings 4 years ago as they were going to be one of my next Fairey builds. Though I have produced drawings for another Fairey since then.
Anyway, not a full on yacht but it has sails! It's a Fairey Fisherman 27 motor sailer. just need to make more progress on my existing builds then I'll make a start on building it.
Boat Show
Cheers Colin
Boat Show
I consider myself to be a model Thames Barge builder and have used moulded hulls as well as building from scratch. Unfortunately the source of the moulded hulls appears to have dried up with the retirement of 'Mastman'.So, it's scratchbuilding for me from now on. I do not use plans either, I work as the real barge builders of old did, and knowing barges as well as I do, I build by eye, if it looks right, it must be.And I've yet to have a failure.
I digress, our hobby has come about from the great Victorian tradition of the pond yacht. Marbleheads and One Metres spring to mind but such aristocrats were nothing compared to the simple model carved from a solid block that every boy received for Christmas. I don't doubt some of our members still possess theirs, or one they've bought since. This is what I'd like to see, loads of very simple model yachts swarming on our lakes. Whether built from kits or not, who cares.
Footnote; yes Ron, a scrollsaw is a great tool to have.
Cheers, Nerys
Boat Show
Boat Show
Boat Show
Boat Show
Boat Show
I read on this site of someone using wooden blinds to plank their boat? There us an idea, better check out the second hand shops .
Boat Show
http://www.bearospaceindustries.com/boats2.html
The Emma design is a great boat and the designer, Gary, does some YouTube videos that are really helpful
On a different note - the lake at Lytham is quite sheltered. If you want a more exposed and windier spot - head along the coast to Fleetwood.
https://fleetwoodmypbc.org.uk/
Boat Show
Good tip if we come to your beautiful island in 2023. .
with left-hand traffic. . . that will be found!
I also got smart in Google Maps, let's see what we will find here! How are the winds there? sailing ok?
Hobbyist greetings from Switzerland,
Michel Claude
Boat Show
Boat Show
I don't believe scratch building is cheaper.
Scratch building gives more flexibility and can provide a greater sense of accomplishment.
But there are many fine kits out there that provide great detail and a great finished product.
And they can always be tweaked.
Just my humble opinion😌
Trev
Boat Show
Derek.
Boat Show
Another vote for the scroll saw here which has had lots of use. My most used bigger power tool. If I had to cut long straight pieces I'd get a band saw as well but so far have managed without.
Boat Show
Boat Show
Boat Show
I did have the benefit of coming from an architectural background which helped with the drawing and getting my head around model construction.
But many beginners are advised, with good reason, to begin with a fairly simple kit and then maybe move onto scratch building if they wish and have built up their skills sufficiently. Scratch building from the off for many would be too much and they would give up and probably leave the hobby.
Boat Show
Without wishing to be too controversial, I must ask why this apparent concession with kits?
While acknowledging that building from a kit is often the easiest and quickest way to start in our hobby, it should be exactly that - a start.
Building from a GF or vac-formed hull, from published plans or even from scratch for both scale and freelance models should be most of our aims.
The results are without doubt better and more accurate models at far lower cost than with the simple assembly of far from perfect kits. What is more the extra satisfaction is absolutely undeniable.
That said, each to his own. It is still a wonderful hobby!
Dr John F. North Yorkshire 😀😀
Boat Show
If you think about it there are relatively few new power boat kits available now either. Only ones that spring to mind are the Fairey ones from SLEC and they are based on timber boats from the 60s.
Trouble is there are fewer model boat designers around nowadays and also recent boats and yachts are generally fibreglass and their sometimes curvy and complicated designs are difficult to build in timber and not viable for production from moulds.
Also, a lot of model power boats are quite simple and can be built relatively cheaply.
Boat Show
So, what is it, more kits equals more sailing craft?
Cheers, Nerys
Boat Show
The Bunker & Ellis were originally built as work boats.
They are so sought after now they are being restored as yachts.
Mine is just a single screw, I may just use the original power train that was supplied by Midwest. some are still available on eBay. Nothing fancy, just propulsion.
First, I have to finish the Seguin.
Trev
Boat Show
https://ellisboat.com/bunker-and-ellis-downeast-boatbuilders/
Bunker & Ellis built many types of these, such as this one seen here.
https://www.ladyben.com/power-classic-wooden-boat/67782-36ft-bunker-ellis-downeast-lobster-yacht-vera-lee-$340000/view-details
Boat Show
I just recently purchased the Maine Lobster boat by Midwest on ebay.
I do like her lines.
Trev
Boat Show
I have never purchase a Ready to Run kit only bought a couple boats from a good builder so my grandsons could easily guide a rc boat which handled well, a Jolly Jay the Dumas kit.
The other, is the Midwest out of production kit, lobster yacht. He knew I admired the style of luxury lobster yacht design and even though he had built it twenty years before the boat runs well. I researched and added more cabin details and figures, plus a dingy.
I did make a plastic kit as seen here too which was converted to a rc version but the same friend gave the kit to me as a gift.
Boat Show
Boat Show
Trouble is there aren't enough new members and builders replacing those leaving the hobby for the obvious reasons and as said the diminishing shops and increasing costs aren't helping with the latter going to become more unaffordable once fuel and food prices really kick in.
I've got a number of RTR yachts and power boats to get me on the water and race whilst I'm doing my scratch builds which are my real interest. I think many of us are interested in anything RC even if we aren't building anything other than boats, I'm building a Tamiya Unimog.
Boat Show
Boat Show
Boat Show
I agree, the personal value of a model is proportional to time and effort you put in to building it and getting it running.
I have built from scratch and I have brought RTR.
I am afraid it is a buy now, think later, society and hand / eye skills are fast disappearing.
Kids want / given iPads , smartphones keep them quiet, parents don't have to spend time with them. kids think they are clever tapping screens and being spied on by big brother.
But the truth is, they are being limited in the skills and interests they need to develop, when they are young which will last the rest of their lives.
Regards old git - Roy
Boat Show
There has been a recent growth in “ready to use” products.
There is a pleasure in building something yourself, even if it’s not perfect, and seeing it working. I wonder if many are missing out on this, through the purchase of completed models and are the required skills therefore being lost?
Boat Show
Boat Show
Boat Show
That would explain the 12M. It's a nice looking model and very close in all respects to my Pond Yacht, and I expect she sails as well as she looks.
dave
Boat Show
Nice display of models. We have as a club exhibited at our local Militaire Show in Crewe UK and they allow all forms of modelling including indoor flying in a netted enclosure. We have not attended for the last couple of years mainly due to age and health issues but hopefully we will attend in the future. I agree fuel prices will impact on attendance for both traders and modellers and we can only hope that market forces will act to resolve the issues whatever those in charge seek to impose.
It is so good to hear that two clubs combined to put on a show that I can see would have a wide appeal to the public in general as well as the avid modellers.
Thanks for sharing.
In view of the recent "weather" in your part of the world I was impressed you only miss the occasional meets during the winter!
dave 976
Boat Show
I agree, here in the U.S. scale RC boat modeling has thinned out some, but it never was that popular compared to some of the other RC model hobbies, RC planes, RC cars (mostly off road), and in the past few years RC tanks. The last local IPMS show that I went to (over three years ago) over half of the contest/entry tables were empty. Many classifications had no entries, some maybe one or two. (video link: .)
Thanks to the local club were able to get three long tables and fill them up with Operating scale model boats and tanks from our two clubs. We had to build "shelves" out of empty boxes to lift the rear models up as the tables were densely populated. I think we stole the show. The operating models are so much larger than the contest entries (i.e. 1/16 scale operating tanks vs. 1/35 or 1/72 static tanks).
Even though our models operate many are very well detailed. The IPMS has a rule about NO moving models so we were not able to enter any of what we built. I don't understand this rule!
The last true model show I have been to was well over forty years ago.
I can understand that "up north" operational scale model boats don't run all year long. here in Florida we operate all year long with maybe missing two or three bi-weekly meets during the winter and a few more at other times due to weather. With great weather and many lakes there are only a handful of clubs spread around the state. I was a member of the national North American Model Boat Association, but they are not very active at all in helping the hobby.
To make matters worse, the economy has likely caused a downturn in members showing up at meets mostly due to fuel prices.
Boat Show
My boat is also known as a The US12 class is a beautiful full keel, spoon bow yacht of the old America’s Cup 12 meter design. She is 46 inches in length with a 16 pound minimum weight, carries a rig of 714 sq. inches of sail area,
Boat Show
While none of these issues is insurmountable, in today's environment, organizers just say NO.
Boat Show
Went to the Birmingham Model Engineers Show at Warwick last week, beautiful workmanship on locomotives and various steam engines, but there was also many stands with boats, plenty of variation.
What I want from a show is Traders, so I can buy what I require without having to pay postage.
Cheers, Pete
Boat Show
Sign of the times and if it keeps model clubs viable I believe we should encourage all form of modelling. Many clubs have linked up with full size sailing clubs and live steam train societies where there is a lake facility.
My own son was into boats, trains and model cars so I do believe it is helpful to have more than one particular interest.
New Brighton used to have R/c cars on the adjacent space by the original pond.
I am sorry to hear that you are disturbed by their presence and would hope they show a bit more regard in the future.
Do the club have dedicated days and times for different sections?
Boat Show
I believe it is a Marblehead - the clue is in the M on the top of the mainsail
Geliked door
Bezig met laden…
