raf arero kits tender plans
On the flip side, my NIMH batteries are stable and have given me years of use, whereas I am on my second lipo battery as the first blew up like a balloon and had to be scrapped.
I'm too old to change now.
Cooling water exits via the exhaust tubes in the stern.
The monitors are fixed position but operate very well using an old 6 volt car windscreen washer pump switched by a microswitch operated by servo arm.
The intakes for Cooling and the monitors are just behind the prop.
All run from 7.2v nimh batteries.
I’m putting a CD together for Westward with some bits and pieces I’ve collected over the years. If you pm me your address I’ll send you one as well if you like?
Neil
As there's not a huge amount to do to I was thinking about monitors that move and pump water. Just wondering what the best options are for getting working monitors and if those of you who have done this are able to share what works.
Also, if anyone has the plans they would be willing to share I would be very appreciative.
thanks
Neil
The other pipe behind this in the photo is the pick up pipe for the water pump that squirts water out of the two fire monitors.
Hobbywing 90 amp speed controller, Overlander Thumper T3548/05 60Amp outrunner brushless motor, 11.1 V Lipo battery and 45mm three blade prop is my set up and it runs just about perfect.
Both have moving and working monitors.
I run them using an Overlander brushless motor on 11.1v lipo battery with a 45mm three blade propeller and get about an hours run time which is very good considering how fast they are on the lake.
. I accept we are all different and all have other tastes and styles. But the RAF Crash Tender's seem to be way on the back step on here now. I know there will be quite a few comments regarding what I have said and I am not saying that you shouldn't like other likes, and yes I do read lot's of them and do get idea's on ways of building and fitting out things but I am just a speed freak I suppose and also the Aerokit all boats as I have 4 different ones of them and just love the MTB styled hulls.I'll Just say a big sorry now 🙉🙉🙉.
Welcome to the site. There are several blogs on the site covering the build or refurb of RAF tenders. Go to the ‘blogs’ area and use the search facility to look for ‘crash tender’. Hopefully that will help answer many of your questions.
Graham93
Geliked door
Bezig met laden…
