Different between leds and lgbts for boat
" is not clear for me if is better utilize LEDS or light "
Scroll right down to the first answer to your query and you will see that Graham 93 already listed the advantages of LEDs over incandescent lamps (bulbs).
"can I use in the same group led and lights? "
If you mean the 6V bulbs that you have from Krick, and working on a 6V battery, then yes.
BUT; remember each bulb will draw 50mA from your battery (checked on the Krick website), this is more then twice what most LEDs will draw. E.g. 10 bulbs draw 500mA, 10 LEDs draw ~250mA.
Also consider that your bulbs are less efficient; more heat is produced with bulbs than light for each watt consumed. At 6V your bulbs consume 300mW (6x50/1000).
Approx 60% (at least) of that goes as heat, i.e. ~180mW, max 120W light.
In contrast, 'standard' 3mm or 5mm LEDs are approx 90+% efficient.
(Not forgetting the power lost in the dropping resistor! V=IxR, P=IxV 😉)
LEDs waste much less power as heat and live much much longer.
I have a long term test running of an LED illuminated polar bear, so far 10 years (87,600 hours) with no failures😀 Far exceeding the manufacture's spec of 10,000 hours😀
But since you already have the Krick 6V bulbs ...!
BTW Back in the days before cheap multi-colour LEDs were available to modellers I used clear (white) bulbs but coloured them as required (red, green, yellow) with glass paint available from craft shops.
If you use the Krick Duo Memory Switch which I suggested you DO NOT NEED ANOTHER SWITCH!!😀 Save your big 20A switch for another project where you need such power. 20A is 100 times😮 the current you need for your LED circuits.
Connection diagram for the Duo Switch attached.
One of your LED circuits goes to output pins A & B, the other one to pins C & D. Make sure to get the polarity (+ & -) right!
The switch works like this-
At the TX you need a three way switch (ON/OFF/ON) or a spare proportional control, e.g. stick or pot. To find out which channel is assigned to the 3 way switch at the TX check the manual or simply plug servos into channels 5 & 6 and see which one reacts to the TX switch.
To switch ON circuit AB push the switch or stick UP and back to the centre OFF position. The circuit will switch on and stay on. To switch OFF just repeat the above procedure.
Similarly, to switch on circuit CD pull the switch or stick down and return to centre. Repeat to switch off.
Each circuit can handle 1.5A, much more than you need. You could run a string of lights all round the deck😁💡💡💡💡💡💡💡💡💡💡💡💡💡💡💡💡💡💡💡💡💡💡
Tutto chiaro?
Ciao, Doug😎
Clear the concept of the 2 switch independently for the 2 groups of LED.
Or even better the switch that you suggest to me 1 switch for 2 groups.
Now just to be sure
The LEDS of one group have to be connect between them in Parallel?
Moreover i understood well that finally is more reliable utilize LEDS with resistor than Lights at 6V? is this correct?
Thanks
That's some well equipped and organised workshop😮 I'm jealous!
Looks like you have your own Airforce as well.
Yes you do need one of those switches for each group of LEDs.
There are 2 function versions to work off one RX channel available, e.g. from Krick Germany, link shows their dual switch version with memory - as shown in Bombero's wiring diagram - but what you showed is a single function type, so you will need 2 channels at the RX.
https://www.krickshop.de/Elektronik-Motoren/RC-Fernsteuerungen-Zubehoer/Elektronische-Fahrtregler/RC-Schalter/Duo-Switch-Memory-2-K-Schaltmodul.htm?a=article&ProdNr=67202&p=1003
In the same time I sent you few pictures of my laboratory that as you know is dedicated for airplanes and now few boats just to enjoy.
In the same time just to be sure you. I fiera me that I need to switch one for each group of lights?
Thanks
I agree with Dave.
Yes that's the one we mean, with the 'Power In' connection, 3rd wire.
Try to get the 4A version and save €2.😉
I note that the maker is 'elechawk'.
330 seems to be the number of buyers who have commented on the unit, given it stars!
BTW Your model looks great, excellent work👍
I envy the space you have in your workshop!!
Thanks
I would select ("the switch with connection with battery") the Marca 330 version at 4amps for both your lighting circuits. This is way above what you require and a 1amp version would be fine if available and possibly cheaper.
Use the power lead from your battery for the lights and also to power the ESC.
Tomorrow morning i will post the info. Thanks
Please don't take my post as a personal criticism.
I know only too well that you have many years RC experience.
Was enraptured by your Blog on your mammoth Olympic class builds, together with your mate (Bruce?)who is now incapacitated I understand. Very sad🤔
I well remember, with great pleasure , our discussions during your Dave_M incarnation.
I distinctly remember one member's response during one of those discussions some years ago.
Can't remember now who that was or what the topic was but his comment stuck in my memory (not much else does these days🤔).
He wrote-
"I love it when you two start chatting. It's like a having cornucopia of knowledge being poured over my workshop floor."
What more of an accolade can we wish for?
I appreciate that in such threads as Fulvio's I may have a slight (professional) advantage.
I spent over 30 years writing system descriptions for complex internal/external integrated for naval COMMS system which were also understandable for the non technical minded, e.g. the Admiral who was committing a large chunk his budget!
I had to make it more understandable than the version I received from development, who of course knew exactly how it worked and left out the (to them) obvious details.
One has to consider 'who am I addressing' (in my case back then; operations officer, COMMS officer, operators, maintainers, logistics or the Admiral who has to justify the expense and foot the bill, i.e. how should I express this topic for him (or her in many cases).
Over the years the feedback I got was good and helped me to simplify and concentrate on the essentials. KISS😊
I would then present the solution (often to my design as proposed in my reply to the Request for Tender) and negotiate the contract with navies and shipyards around the world.
I try to use the same principle here, cut to the chase😉
All the best, let us know what you are currently creating sometime👍
I think fulmic should now have sufficient info to wire up his system. I really wasn't trying to confuse novices but was responding to specific questions from the original poster.
I accept this is a complex topic and different countries will have different types of equipment which can add to the confusion.
Like you I have many years of experience with RC and am happy to share this with others.
To avoid any further confusion can you please post the manufacturer and type numbers of the ESC, RX and RC Switches that you have. With photos please!
We can then check the specifications to make sure they will work together as you want.
What is the model that this will be fitted in?
Please also advise if any other auxiliary functions will be fitted; e.g. water pumps?
Thanks in advance.
Dave, Len,
I tried to finally clarify things for Fulvio based on the equipment that he apparently has, esp. re Switchers which have no separate battery input. Now I fear he (and other novices) may be more confused than ever.
Seem to be some misconceptions or maybe unfortunate typing errors. A few points in your posts that surprise and puzzle me.
1. "not all RX have a BEC circuit"
To the best of my knowledge and belief NO RX has an internal BEC circuit.
As the name suggests😉 the BEC (Battery Eliminator Circuit) is in the ESC for the purpose of eliminating the need for a separate battery for the RX supply. If you apply a voltage to any of the RX sockets that same voltage will appear at all the other sockets, regardless of where it comes from.
2. "As regards the current draw I agree with Doug the level will not shorten your sailing time when connected to the main battery."
Even if the switcher and it's load are powered via the BEC the current supplied to the load is still coming from the main battery!
3. "I was advising against using the internal ESC supply from the RX which might struggle driving a servo, the ESC and your lights as well as being 5v."
Why? The ESC draws it's internal circuit power (a few mA) direct from the main battery, usually over a range of voltages.
A typical 'standard' servo draws about 500mA in short bursts. Even if multiple servos are fitted the chance of more than 1 or 2 operating simultaneously is remote.
The RX and Switcher draw only a handful of mA and, as we've seen Fulvio's lights will only draw about 200mA worst case. So even a 1Amp BEC should cope with Fulvio's setup.
5V; I trawled around for so called 6V LEDs and they are generally quoted with an operating voltage range of 4.8 to 7.2V. At 4.8 they will of course be a little dimmer. But IMHO that's no bad thing as often model lighting tends to be too bright and harsh anyway. I've also noted recently that some ESC BECs now provide 6V. Check specs before you buy😉
4. "You can use a 'relay' connected to a battery but make sure it is a relay that has an independent input".
Len; I assume you meant the Switcher here? Some of which use a separate battery and relay for high current switching, and to isolate the high current load from the switching circuit and RX supply. A prudent precaution if the load is a DC motor, it prevents the back EMF from the motor when starting and stopping from potentially damaging the RX.
Most of the tiny (oriental) ones use a low resistance FET (Field Effect Transistor) as the output switching device. Usually good for 1 or 2Amps and often use the supply volts from the RX to feed the load.
5. "Do NOT use the type that has a receiver 3-wire plug on the input end or if you do, make sure to remove the control wire ...".
Sorry, can't get my head round that at all. Control wire to me is the signal wire from the RX. Remove dat and da switch don't woik at all🤔
"the type that has a receiver 3-wire plug on the input end"
That indicates that the switch takes power for the load from the RX, which is what I believe Fulvio has. See the pic he posted way down in this thread.
I think we may have finally given you a solution. The picture posted by bombero shows a setup that is what you require albeit you will be using two units on separate channels.
As regards the current draw I agree with Doug the level will not shorten your sailing time when connected to the main battery. I should have made it clearer that I was advising against using the internal ESC supply from the RX which might struggle driving a servo, the ESC and your lights as well as being 5v. Not all Rx have a built in BEC and the BEC output from an ESC would normally cope with 2 to 5amp.
Connect the switchers directly via a fuse to the main 6v battery and LEDs and plug into your chosen Rx channel.
Happy days
To attempt to finally cast light (😁) on your LED problem!
You have bought "6V LEDs". This means that they already have a resistor fitted, you do not need to add another one.
So you have no choice - you MUST connect them in parallel to the 6V power supply (as in Bombero's diagram, although that is an old version showing incandescent lamps!).
You have two circuits; 3 LEDs on one and maybe 4 on the other. Total 7.
The LEDs will draw on average 25mA (25/1000 Amps).
25 times 7 = 175mA.
Even if they draw 30mA each the total is still only 210mA.
I understand that the RC Switches you have take the power via the RX, i.e. from the BEC supply.
I do not believe that 175 or 210mA will cause any problems or significant reduction to your running time and will certainly not overload typical BEC supplies of 2 or even 5A.
Hope this helps to 'enlighten' you!
Look forward to seeing some pics / vid clips of you model.
Vice versa without the direct battery connection with battery (switch with 3 cables) and i have a switch with one connection to Rx and the other side i connect to leds i can use just one led or maximum 2 Leds connected together on the same switch in order to not suck to much power via RX. Correct? Thanks
The switch to utilize is the same of the attached picture? in this case of course one side i plug inside the RX at the channel 5 for example but at the other side of the switch can i connect 3 leds for example? of course i jont 3 led in one female plug to connect with the switch but the topic is this switch can supply 3 leds in one time or i switch is only for 1 led?
I am an exflyer so we have similar history.
I believe you understand so far but perhaps I need to explain in more detail about the switching unit. You have Graupner Rc equipment but have not detailed which Tx you are using. I am assuming the Tx has a few switches as well as the usual stick or Knob proportional controls and that you will be using a couple of the switches to control the two light channels via the Rx.
You will need two switch units that plug into the Rx and also connect with your main battery and the Led lights. Suitable units are available on line and if you Google "RC Remote Controlled AUX on/Off Electronic Switch JST Male & Female Cables 2/20A" you will see several options on e-bay. Relatively cheap at
Based on it i bought a Graupner Krabbe 12Ton old but still in box. I started to assembly and to paint now the model is almost finish from the structure point of view and i start to approach the light topic.
In the model i will use a RX Graupner GR12 and a battery Pb 6V to supply power to RX via the ESC of 10 Ampere due to the fact that the motor a Graupner Speed 280 utilize max 2 Ampere.
In this case i already tested Esc, Rx, Motor and battery all works perfect.
Now i start with lights.
I bought LEDS 6V diameter 3mm. I bought green, red and white color.
My concept is to split the lights in 2 groups. One group the so call position light (green, red, 1 white inside cabin and 1 white color in the back of the model. Second group i would like to put 3 o 4 LED white color around the boat as working lights in order to make light on the brig where the people operate with fish. In this case first group of lights just to move the model and second to work. I need to consider that group 1 and group 2 of the led can be ON in the same time.
On the draft that i send you before in priciple you can see the 2 groups of LEDs. Up to now i set up to exit from the main battery. One live to the ESC just for motor and RX. The second wire exit from main battery always 6V will be to connect the full LED system. Now if i devide the LEDS in 2 group how i control the 2 groups? i understood is better do not go true the RX and this is clear. An so how i can do? I can use a switch to connect to RX and in the other side of switch i connect a group of LEDS? but in this case as you wrote can be a problem for RX because to much leds on each group. This is my actual situation and understanding on the topic. Maybe i need some different device or switch that can support more leds for each group? in a previous model of boat that also i bought months ago (Graupner ELKE) the lights was installed already (leds) but the system in part done included the solution to utilize servos (regular servo) to close the contact circuit in this case the power was not truogh the RX but was indipendent line only for light but i utilized 2 servo as switch. Now in this new model what is better to do?
Thanks
If I understand you correctly you wish to control two banks of leds using two channels on you Tx by a couple of switch units.
You have purchased 3mm leds with resistors suitable for a 6v supply. If you added your own resistors the values shown in your second diagram are ok.
If you are using individual resistors then you need a 6v supply to each LED. The LEDs will be connected in parallel and brightness (current) controlled by the individual resistor.
You have not given details about your switching units so I am not sure if they will be switching your 6v supply or using the 5v from your rx.
The ESC will be giving a 5-6v relatively high amp output to the rx but there may be a further regulator in the rx which may not be as high an amp output. You could therefore overload the Rx and cause malfunction.
A separate switch of the main 6v battery will be best.
I did indicate that Leds have a maximum voltage depending on their colour and you can buy LEDs with pre attached resistors to work with a range of battery voltages. The resistors reduce the voltage to the safe working level for the LED.
In summary you can connect any number of leds with resistors in parallel to a 6v supply providing the battery has sufficient capacity.
If you do not wish to use resistors you can connect leds of the same type in series and for a 6v battery up to 3 or 4 will give a bright light adding more will give a dimmer light. This is based on an average LED voltage of 2v.
I should mention that early coloured LEDs were not super bright like modern types but I suspect most you can buy today are bright.
Please ask if you need more help.
Thanks for your clarifications, but due to my school knowledge i am far for eletrical topis. For this reason i need to ask you almost the same things but in my way. I will utilize for my Graupner Krabbe 12T a battery 6V Pb at 2,8 A/h. With the same battery i would like to energize the LEDS.
Here i attach you can find what is my project in order to understand how many Leds i will install. I understood from the posts that is better in Parallel. But what for example is not clear why you mentioned 2V for LEDS. I have a battery 6V and i bought the LEDS for 6V with 3mm diameter. In this case can i Use at 6V?. Moreover can i use for example 4 leds and all 4 leds jont in a single connection that i connect to channel 4 for example of my RX? in different way can i connect more than one LED on a single channel of the RX powered always from the main battery at 6V? I atatch to the present mail the draft of my project in order to have your techncial opinion.
Thanks
I agree with the previous comments but would add LEDs are polarity sensitive so have to be connected the correct way round to work. I have used LEDs for many years as they are far less likely to melt fittings and have a much longer life than incandescent bulbs.
They are not however universal in their voltage requirements due to the different doping used in the internal crystal structure. The typical voltages are: Red-1.8v; Yellow-2.2v; Green-2.2v; Blue-3.2v; White-3.2v. Nominal current for 5mm is around 20mA but much less for 3mm and surface mount types.
I have used electronic circuits to reduce the voltage from my main batteries as this allows me to adjust the current and hence the brightness to the LEDS. I use parallel connections to save many wires. I may have more than one electronic circuit if using different types of LED. In the case of running Red and Green lights they need to have their own supply (I use a resistor) due to the different voltages as above.
You will not regret using LEDS and there are commercial circuits cheaply available that will provide the required voltages.
Good luck and please post details of how you proceed
Len
https://model-boats.com/blogs/102552#115229
Lower current draw also allows for smaller gauge wire to get into tight spaces (the resistor does not need to be near the LED). Good example here would be lights mounted on a mast. Also, more LEDs can be used for a more even light, especially interior lighting.
1. Longer life
2. Lower current draw for similar light output
3. Run cool, very little heat generated.
You can add to those fundamentals:
4. Available in a range of sizes down to very small
5. Available in a range of colours
6. Available with flashing/flickering options.
7. Available in a range of shapes.
Disadvantage - they need a dropping resistor or a constant current supply.
Graham93
Geliked door
Bezig met laden…
