A Build Problem With My Aeronaut Diva Cabin Cruiser
Volgers (4)
- mturpin013Bronze
- Newby7Bronze
well,i have built the "victoria" cabin cruiser and the biuld is similar to yours.you have to glue the roof and the floor,together with two side pieces which you might have to make yourself from scrap in order to make one unit so it fits in the big oblong hole in the back half of the boat! and try to make it a very comfortable fit so it
s hard for any water to find its way in.i had to work it out too! but it is fine!
Anyway, thank you for your help and suggestions.
Greg 👍
Greg
When you get the cardboard to fit lay it on the back side of the floor to judge how much you need to trim.
When you have the area to trim slowly sand the edges down to fit. Rick
And always place the widest end in first.
Hope that is helpful to you, cheers Colin.
I am at the stage where the instructions are telling me that I now have to fit the cockpit floor (see picture). The instructions say to insert the floor into the hull and slide it down and all the forward until it touches the cabin wall. It then goes on to say about fitting the bench seat at the back. I can't see if there is an error with building the hull because when I insert the floor as instructed it is too wide for the opening in the hull and will not side down into place to rest on the supports in the frame. I don't want to push too hard to try and get the floor to fit because it will only stick to the inner sides of the hull or damage the inner hull and/or the framework.
For the life of me I can't see what is not correct. Why it won't fit. The inner frame as far as I can see is correctly built and the floor which is a laser cut part has not been altered. It just does not slide in as instructed.
If another pair of eyes and brain can see what I have done or not doing to get the floor to fit I would be very grateful to hear from them.
Greg
Geliked door
Bezig met laden…
