Battery Box and Receiver Cover
Gestart door firefighter
10 replies 36 vind ik leuks Laatste activiteit: 4 jaren geleden
I have a few yachts and a few motor boats but to date have not used a box to keep water out of the electrics. On occasion some items get wetted but dry out quickly without any problems. Only once has all my kit got wet, and that was when a motor boat sank whilst under power. A week later I rescued the boat from 7' deep water, removed all the electrics, took them to bits, dried them out (lightly oiled or greased where appropriate) and lo, everything worked again, no problem !😉
Geliked door Ronald and Graham93 and
Even if you do use a sealed box it’s always a good back up to put a rubber balloon over your receiver and battery pack with a elastic band sealing were the cables enter. 😎
Compare yourself with others and you either will become vain or bitter.
Geliked door Mike Stoney and firefighter and
A small tupperware type box is a good substitute for the traditional screw topped radio pot...
Geliked door firefighter and hermank and
I use a food containers with a clip on top, I put a false floor in it to mount all the 'lectrics and a fan on the lid should things get warm, that is the only way wet stuff can get In.any cables exit via a hole fitted with a rubber grommets sealed with silicon, Box is then screwed down inside.🤞😂😂😂
Hello Ron,
Thank you for the information. Yes of course, I should ask Peter. I didn't think to do that. Good job you are around. 😀
Greg 👍
Best regards,
Greg
Geliked door Colin H
Send an email to Peter with the Footy Association.
I am not aware of water getting inside the Footy design. I do take precautions even with my larger sailboats by using a clear “Hockey Sock “ tape applied to the seams of the cabin and deck just before sailing.
The receiver is not in any type of container. I keep the receiver in position using velcro and it is located high up in the cabin or tucked in under the deck.
My batteries are secured too. I also put my on/off switch well protected from water but accessible from the top of the cabin.
When sailing, I try not to allow water over the rail it’s not racing, just pleasure sailing.
Geliked door dave976 and firefighter and
One possibilité is using a Tupperware box cut 90 % away from thé bottomsite of the box use what remains to glue that in your deck and close it with thé lid of the box and your modell is 100 % watertight
Geliked door Mike Stoney and RodC and
With regards to the Footy Bob-About I am building. I will need, when sailing, to protect the battery box and receiver from getting wet. Apart from the obvious of putting them in a plastic bag and taping are there any cover devices that will do the job of stopping them from getting wet that anyone knows of?
I have seen these devices online but I am after recommendations from the members.
I will be using an open switched battery box which takes 4 AA batteries and a FlySky receiver.
Greg 👍
Best regards,
Greg
Geliked door hermank and RodC and
