fin stabilisers
fin stabilisers
Very similar vessel to the Sentinel and no doubt it will heel at speed. The Becker arrangement would certainly help but I'm not sure how effective the arraingement might be on a scale model. The stabilisers will certainly help in the turns.
I guess you will be considering the gyro to control the side to side roll and with a beam of 310mm there will only be 150mm either side of the unit.
Paul may be able to give more advice on its suitability now that we have the intended usage. Would you consider a build blog on this model as the subject will be of interest to others on the site.
Good luck 😀
fin stabilisers
I have included a photo of said items on full size vessel so as to give a clearer picture of my intentions.
The vessel in question is the German Coastguard and Fisheries Protection vessel Seeadler.
My model has a total length of 1644mm and width of 310mm (scale 1:43).
It will be powered by a pair or Torpedo 850 motors and 2.1:1 reduction drives throuth 60mm 4blade props.
Steve
fin stabilisers
Steve
fin stabilisers
fin stabilisers
I helped a fellow modeller install working stabilisers on a Model Slipway Sentinel Coast Guard cutter and although manually linked to the rudders they did reduce the heeling effect at high speed. Your mention of Becker rudders suggests a trawler so I am interested to hear on which model you intend to use the stabilisers.
fin stabilisers
I intend to use a pair of modified becker rudders as the stabilisers so as to keep things as close to the original vessel as possible.
Steve
fin stabilisers
Paul
fin stabilisers
Any advice would be appreciated .
Steve
Geliked door
Bezig met laden…
