Switched Battery Box
Gestart door firefighter
14 replies 22 vind ik leuks Laatste activiteit: 4 jaren geleden
Hello Dave,
Thank you for the information. Okay I now see what the addition lead is for. The battery holder takes AA batteries of which I was going to use just disposables but I might now purchase some rechargeable batteries as well.
Greg 👍
Best regards,
Greg
Geliked door Colin H
Greg
That charging lead is really helpful. When the switch is in the off position you can connect this to a battery charger and charge the battery up without having to remove it from the boat.
Geliked door firefighter and Colin H
Hi Greg
The switch unit is designed to allow you to switch the power from the battery on or off. The two connectors together are a female to connect the battery and a male to connect a charger. They are connected together when the switch is off. The single male connector goes to the rx and is connected to the female battery connector when the switch is on.
A fuse is always a useful protection feature but personally most of my models use one battery which I unplug and remove from the model when not in use so have no need for a switch. My experience is that switches can and do fail and create another possible fault point.
Geliked door firefighter and RNinMunich and
A picture of your battery box connection would help immensely, to help you select the correct plug or socket to connect your switch to, and which is to the rx battery input.
I'm surprised that it didn't have an instruction leaflet.
I have just fitted the battery box and receiver on my Bob-About sailboat and I'm just about to fit the switch for the battery box but once again as a person with a limited brain to understand what I have here in front of me I'm now confused again.
The switch unit has two wires on one side. One wire terminated in a socket and one terminated in a plug. the other side of the switch has one wire only which is terminated in a plug. Obviously the plug on the wire from the battery holder goes into the socket on one side of the switch and the switch is then connected to the receiver by a wire with a plug but what is the other wire with the plug for?
I have added a photograph for reference.
If anyone can help I would be grateful.
Greg 👍
Best regards,
Greg
Sorry for the delayed reply. For some reason I have stopped receiving response notification emails to my posts.
Hello Doug,
Thank you for the advice. I have got the fuse to add to the electrics.
Greg 👍
Best regards,
Greg
Geliked door RNinMunich
Hello Bill,
Thanks. Yes I got some fuses and holders having been recommended to use them to protect the electrics.
Greg 👍
Best regards,
Greg
Geliked door RNinMunich and Scratchbuilder
Hello flaxbybuck,
Thank you for the good advice.
Greg 👍
Best regards,
Greg
Hello Colin,
Thank you. I understand what you have said but I was a bit confused (doesn't take much these days) when I saw that I could get one with or without a switch.
Greg 👍
Best regards,
Greg
And a 'fuse box' in your boat as well!👍
Protects the wiring from overheating/burning and prevents potential fires 🔥 from burned up motors and/or ESCs.
Doug😎
Geliked door firefighter and Scratchbuilder
Agreed chaps.
Always have a switch box.
Same principle as a fuse box in your house.
You can get them with a charging cable to save disconnecting if desired.
Bill 👍
As Colin said, yes, you should always have a switch in your power supply. This not only enables you to isolate your equipment from the power (to protect it) , but it also saves you from the need to disconnect which can in cases be a tricky operation.
If you have the choice of a battery box with or without I would go for the switched one.
Hope this is of some help 😉
Some help please. When I purchased the battery box (To take AA batteries) for my Footy class Bob-About sailboat I was told by the supplier that I would need a box that had a switch harness included which I purchased. When I emailed the supplier to ask the question why it need to be switched unfortunately I did not receive a reply.
Please could any member tell me why the box has to be switched, because when I checked the sellers site there were two boxes for sale. One was switched and the other which was an identical box was unswitched. Why the difference?
Greg 👍
Best regards,
Greg
Geliked door Scratchbuilder
