MFA Torpedo 800
Gestart door Cpt-Pugwash
6 replies 22 vind ik leuks Laatste activiteit: 3 jaren geleden
MFA Torpedo 800
That's a very nice model and I agree with you about the cruising.
A good scale model should cruise nicely at a fast walking pace.
My Caroline manages 13 knots true speed which is a tad fast but half throttle is perfect.
Geliked door AlessandroSPQR and Cpt-Pugwash and
MFA Torpedo 800
It is a big motor I agree, but all the smaller quality motors peaked near 20k rpm and I wanted the throttle control a slower motor would give me. It should cruise nicely I hope close to half throttle.
May4th be with you!
Geliked door AlessandroSPQR and Doogle and
MFA Torpedo 800
Thanks Colin.. A lovely craft. You must be very proud of her.
Mine has yet to see the water with me. The little girl is a shade under 4ft.. I acquired used and I'm in the process of refitting the running gear. I had no idea of the condition or service life of the original installation so I am starting from new. Your input is most helpful!!
Regards,
DG
May4th be with you!
MFA Torpedo 800
Good morning DG, my boat MV CAROLINE runs a 4 blade 75mm brass prop running on 12 volts . See the details in my harbour.
Geliked door hermank and Doogle and
MFA Torpedo 800
If you are running a MFA 800 motor, what size prop are you running??
TIA.. DG
May4th be with you!
Geliked door Colin H
