Identify this Boat
Identify this Boat
Identify this Boat
Thanks for idea, and yes it is a good flare on the bow, with the top (27ozs) removed it really does plane well and with a pair of 7.2 volt NiCad's managed 15 mph.
So the idea of a fast fishing/smuggler boat intrigues me. Have you any photos of this type of vessel or could you please tell me where to look.
Thanks Colin.
Identify this Boat
The hull is very flared at the front so most likely a fast type vessel such as you suggest. Looks rather heavy but difficult to judge with all the paint! Are you intending to strip the hull right back? it will plane better if you can keep the weight down. My preference would be a fast attack naval craft but a fast fishing boat used for narcotics smuggling would be a novelty 😀
Can't wait to see your build blog, whatever you choose
Identify this Boat
Yes I agree the deck up, is made from solid blocks of balsa and ply, roughly shaped and painted. So this will all be recycled into other parts for this or another build. I have some plans that I thinks would be usable to create a superstructure to suit this Hull.
So far possibles are:-
1-Fire boat.
2-RTTL
3-Fast patrol boat.
4-Motor torpedo boat.
5-Fast fishing Boat. (based on one I've seen in Abberystwith Harbour)
Any other suggestions will be added to the list. Another thought just accurd to me, maybe able to use differant tops on same hull to give differant boats. I'm just thinking as I type.
Identify this Boat
Identify this Boat
So any Ideas that you guy's and gal's can think of would be warmly welcomed.
Twin screws, on direct drive from 2 off Ripmax 600 motors (working),
twin rudders on single servo (working),
27Mhz Hitec reciever (untested as no transmitter).
Viper marine 20Amp ESC(working).
The Hull Is 35.5 Inches long.
Throw the Ideas In the pot and I'll see what we get In the mix.
Thanks for looking Colin.
Geliked door
Bezig met laden…
