Pcf Swift boat
Volgers (8)
- Commodore-HGold
- jumpuglyGold
Pcf Swift boat
All 5 of my large ( 4 ft long ) run scale like on a 2S ( 7.4 volt ). Both brushless and brushed motors.
My newly acquired 6.5 ft long boat will need 3S battery running 3 geared motors.
See how it runs in the water before going to higher voltage.
My opinion.
Isaac
Pcf Swift boat
He seems very comfortable in the new environment.
Pcf Swift boat
Pcf Swift boat
Pcf Swift boat
Pcf Swift boat
Pcf Swift boat
I haven't decided if I am going to add an engine sound maker. Right now, lights work, radar revolves and auxiliary steering wheel turns with rudder. Do I need it to make engine noises? I can just purchase one and wire it in.
While I am waiting, I decided to build its carrying tote. Boat models are seldom damaged while sitting on the shelf (yes, dust) or sailing on the pond. However, problems can arise while moving them about, so each of my models has a custom made carry box. I want to show and talk about these but I will show them in a separate post.
Pcf Swift boat
Pcf Swift boat
Pcf Swift boat
Pcf Swift boat
PCF is nearly complete , models are never totally finished.
I added the the rear deck railings. As I see it on plans and pictures. the upper rail is cable and the lower rail is solid pipe. So I needed to drill small holes in the stanchions for the cable. This is my setup for precisely drilling tiny holes. A cheap Chinese mini drill press with an X-Y table and small vise. The drill press is not too good but, it is heavy, a good thing for this kind of machine. The X-Y table is from Little Machine shop and is quite good.
The entire rail is K&S brass, 1/8" for stanchions, 1/16" for the rail. Lower rail is soldered using guide blocks I made to keep everything aligned. Upper cable is steel fishing leader I painted gray.
Pcf Swift boat
The radar runs smoothly and realistically, the water jet seems to work very well.
Pcf Swift boat
Seen in the background is my Coast Guard PWB, Ports and Waterways boat, "Sprinkles". If it works, there should be a short video of Sprinkles "in action" rotating blue light, firing water cannon on a warmer day.
Pcf Swift boat
I confirm my appreciation for the way you paint and the attention you take to detail.
The twin-linked machine gun (.50 caliber BMG 12.7 x 99 mm NATO if I'm not mistaken) is fantastic.
Excellent working method and very intelligent solutions adopted.
I really like how you work (or rather how you have fun).
P.S.
"Work continues on my PCF build, but it's painfully slow. My lab is in the basement, heated but still cold."
I understand you.
As an alternative to the living room table, I have a wooden shed for tools but in the winter it is frozen and in the summer it is a sauna.
Pcf Swift boat
I keep adding details and the graphics ( by Callie Graphics) are now in place.
I added the internal wiring. I like to do this by building a wire harness outside the boat, testing everything and then installing it and making small adjustments.
I've put rotating radar in several models. To make it "go round" I take a cheap eBay servo apart and remove everything except gears and motor. I like to be able to keep the radar turning with the boat just sitting on a table. So I power the radar independently with just a single "c" battery. The mechanism is switched on by pulling up on a scale antenna that is attached to a hidden slide switch.
In this case I just put the whole servo on top of the mast because it resembled the actual radar enough. I like my mast to be removable when transporting the boat as they tend to be the first things damaged. I mounted a phono plug on the bottom of the mast and hidden socket on the boat so the whole thing just plugs in.
Pcf Swift boat
Yes, the boat in the picture is the type I am building, but I think has additional railings because it is used to give tours. Mine will have railings around the aft main deck which are already made. The railings have cable on the top rail and hard pipe on the lower rail. I won't install these until I add few more things like wiring the motors, speed controls and lights as these will be in the way.
Pcf Swift boat
Is this an example of the type you are building, if so, I have answered my own questions.
https://sdmaritime.org/visit/the-ships/pcf-816-swift-boat/
Pcf Swift boat
Whawwwwwwwwwww
I can‘t find the words to Express my admiration
Madre Madonna what à jewel
Pcf Swift boat
I follow you.
Pcf Swift boat
Pcf Swift boat
My method for a successful paint job is to do everything in primer. So...first fill sand, prime, when all the flaws show up, fill and sand again , prime and repeat until it's good enough, (when it's good enough, not perfect I quit messing with it ). When I paint that just adds the color.
The control of dual the rudders is the simplest possible set-up.
Pcf Swift boat
I congratulate you on this model of yours.
It reminds me a bit of the movie "Apocalypse Now".
I really like the images you shared.
I would have also appreciated those of the processing phases.
I will follow your work with interest. Hope you provide many more details about the complete RC setup.
Pcf Swift boat
Power will be from dual 555 Mabuchi brushed motors purchased on eBay and 12v. I will see how it’s goes and decide to keep that set up or not. There is an exposed aft steering position and I will hook a servo to that wheel so it will turn when the boat turns. There will also be working lights and revolving radar.
Geliked door
Bezig met laden…
