Aerokits pt boat bulkhead plans wanted
Gestart door andrewandrachelh
8 replies 11 vind ik leuks Laatste activiteit: 3 jaren geleden
Glad you got sorted then and it's always good if folks post about their builds, even if just when completed.
Geliked door Len1
Yes it is me on both forums. I have now found the plans .I do not do much with boats many rc gliders so do not post much
Geliked door Len1 and ChrisF
I assume he has via Mahem as someone with a different name asked for exactly the same which would be too much of a coincidence.
Maybe he will update us on here, if that is the case, but after only 2 posts over 14 years, both asking for plans, I'm not holding my breath! 🤔
Geliked door Len1
I am pleased that you may have found what you are after. My reason for asking was because I don't have any way of making a PDF, but I have drawn out on carboard the bulkheads of the RAF Crash Tender. I could have sent you these in the post if you couldn't get anything else if these would have helped you.
BOATSHED
Geliked door AlessandroSPQR and Len1
I think someone is sending him some now.
Geliked door Len1
I did CAD drawings for an 1/24 Elco 80' hull many years ago using the line drawings provided by John Lambert and Al Ross from their book Allied Coastal Forces of World War II (awesome source for building MTB's) as a reference.
John Drain's site at pt-boat.com is also is a great reference, and he might be able to provide you with a PDF of the hull section lines I got from Allied Coastal Forces, so you can project the bulkheads and the transom for the Aerokits Plan and Elevation drawings.
Geliked door Len1 and BOATSHED
What are the difference between the AEROKITS PT BOAT and the AEROKITS RAF CRASH TENDER. I cannot seem to find a picture of an Aerokits PT Boat anywhere.
BOATSHED
Geliked door Len1
Aerokits didn't tend to include bulkheads in their plans unfortunately.
You may be lucky and find someone who has built one from scratch in the past, drew the bulkheads out and kept the drawings, otherwise, you'll have to draw them out yourself.
Will
Geliked door Len1
