Need help in identifying a brushless outboard motor
Volgers (4)
- DWBrinkmanBronze
His motors have the steering and tilt servos built in, so the motor is essentially self contained.
I've seen them run, and they work well.
He has done a really nice job of making them detailed.
Here is a link to the outboards on his webpage:
While there take a peek at his pontoon kits.
Sorry if this post is against any rules, if so feel free to delete. I'm just trying to offer an alternative solution.
https://spykerworkshop.com/product-category/rcboats/outboardmotors/
"I'm pretty confident that it started life as one of these (see link below). The only question I have is the adjusting screw on the front of the lower unit. The motor in the eBay link doesn't have it. Everything else matches. The only motors I know of that have that adjusting screw are some (but not all) of the '52-'54 K&O Johnson and Evinrudes. The lower units on those look the same as yours, but the transom clamp assembly on a K&O from that time would have a chromed spring clip fit in around the portion of the assembly attaching it to the motor. I'm pretty sure the spring clip was to maintain friction in the steering pivot, so whatever steering angle you set stayed. That's why I'm leaning toward the generic "Speed" brand."
Based on the age, the brushless motor is surely an upgrade added later. I looked at the ebay listing he sent, and what my friend Rob said makes sense.
I hope this helps.
https://www.ebay.com/itm/374846703446?fbclid=IwZXh0bgNhZW0CMTAAAR0KPKJSfmIYH18B89QfV-htM23RyOJRy5RXxup4cLLCesfOVm8wDU3OEFE_aem_AaiNY7BEzRoX9ifQKlC0pELNV6-iqYRZjE_R08xM9FYDLWIL2ygE1sEbveKEWO3d_Lf77FfjpvODNxTSHutpoA7x
There is something strange with that outboard motor as it looks like the brushless motor was an after market modification. ( I am probably wrong, but it looks like old meets new ).
In any case, this should be a fun project. 😎😎😎😎
Isaac
Need help to identify this outboard motor. Tried looking up the manufacturer names and numbers. Found some info on the escarpment and actual motor but not the complete outboard.
Has anyone ever used this outboard?
Planning to use it on a skiff that was a static boat. I saturated the inside and out with paint and polyurethane. Going to make it a boat that is transporting illegal alcohol.
Geliked door
Bezig met laden…
