Decals
Volgers (10)
- WestwindSilver
- robbobSilver
- roycvBronze
- Commodore-HGold
Decals
Decals
I see that you have already ordered some stickers elsewhere but I thought you might like to know of a UK supplier that I have used for custom vinyl lettering and numbers.
I used them for some custom lettering on my Southampton Pilot Boat and they were excellent 👍.
Decals & Stickers are based near Manchester UK.
https://www.decalsandstickers.co.uk/shop/
https://model-boats.com/blogs/71877
Robbob.
Decals
Decals
One more method... you might not have noticed it but on my last Springer tug build I have the simulated openings for the "water coolers" by painting them on (black paint).
After figuring out the pattern I 3D printed a mask. I then taped it on (both sides) and spray painted the pattern. Attached photo shows the mask and the finished pattern on the hull.
This could open up an entirely new way of applying artwork. Either make the mask or I assume it is possible to actually 3D print the artwork real thin then cement it to the model. May not work in every instance, but might be worth a thought.
Florida, USA 🇺🇸
Decals
So, perhaps not for transfers but decals thin plastic and sticky this works very well and I have used this way for many years.
First peel the backing off and place the decal into warm soapy water. Leave it for a bit and make sure the surface it is to be stuck on is cleaned and wet.
Take the decal out and position it where you want. It can be slid about until you are happy. Then, with a sponge, start at the centre and firmly squeeze out all the water and any bubbles. Because it is warm, the decal will take up any slight curve without any difficulty.
Gently wipe dry and job done!
Yes I didn't believe it until I tried it!
I was finishing a model yacht (Graupner Libera Ocean) and it has the name about 10 inches long to be applied to the hull sides.
This way it was placed exactly in the right position, which I doubt could have been done the dry way.
Decals
Decals have their place as well, especially surfaces that are irregular such as rivets or seams. There are softeners to help decals to conform to such shapes. The vinyl is thicker than the decal base.
I would not throw out my decal paper.
Florida ⛱️, USA 🇺🇸
Decals
Yes we are on similar wavelengths. If you colour background, draw decals and then remove them from the background. when you print it the decals will be the same colour as the target medium
Len
Decals
Decals
However, I also use white decal paper which allows me to print a decal with with white in it or even light colors (the color on a white background) because just printing a "light color" will not work on clear decal paper, especially if the model is dark.
As the entire sheet of white decal paper is solid white any background that needs to show through (the model) within the perimeter of the decal will need to be cut away or painted it after the decal sets.
Attached is an example. The star can be multiple pieces or one piece with the non white parts green (what Idid). However, it is very difficult to match the inkjet green segments within the star with the model finish. I must use paint and brush in those areas. Same with the numbers.
Florida ⛱️, USA 🇺🇸
Decals
Decals
Decals
Geliked door
Bezig met laden…
