Prop shaft lubricant
Volgers (13)
- zoomaBronze
- EdWBronze
- Stephen TGold
- GregHiltzGold
- Commodore-HGold
- tim morlandSilver
I use an oiling tube fixed to the prop shaft casing but to get grease down could be problematical. Presumably you have to remove the prop shaft and inject it, or am I missing something?
Alternatively, you could get a replacement bearing custom made locally if you know anyone that owns a small lathe.
A model engineer would find this a simple job and may well have some phosphor bronze bar stock to turn it from.
Perhaps oil is more problematic, less practical to use.
I always tell people to add 10 to 20 drops if 80-90 weight gear-oil, once per year into the tube
Same as with Rudder through-hull bushings, a machine a slight V-chamfer into the top of the bushing, and add 1-2 drops oil there too.
Can anyone on this group suggest a suitable oil or grease to lubricate prop shaft please. One of my boats has a small amount of wear on the propshaft bearing and leaves and small oil slick when she is sailing Replacing prop shaft and tube is a possibility but VERY difficult. Thin grease or thick oil perhaps? Suggestions please.
Best wishes Tim
Geliked door
Bezig met laden…
