Dead short
Gestart door Stephen T
6 replies 19 vind ik leuks Laatste activiteit: 2 jaren geleden
Dead short
Some pictures would be very useful to help you (Seeing pictures reveals many things that words don't say), otherwise we are groping in the dark.
Dead short
Stephen,
If it is a brushed motor and speed control, then the leads to the speed control are positive and negative. If they are reversed, you will probably fry the speed control. The leads from the speed control to the motor are reversible. Swapping them will only cause the motor to run in the opposite direction.
IF you reverse the positive and negative feeds to the speed control, ones that should be connected to the battery, hopefully with a fuse in line on the positive lead, with the leads from the speed control that should be hooked to the motor than you may show a dead short, or again, fry the speed control. Not know which ESC you have, I have found that some Chinese units are very lacking in directions and some even come with improper color coding for the wire leads.
Hope this helps.
Geliked door PeterL3 and Peejay and
Dead short
Hi Stephen, with so little information I can only make some hypotheses to try to help you.
You could attach some photos in which you can clearly see both the wiring and the individual components (motor, esc, battery).
I ask you this to try to verify: how the wiring is made, the state of the individual components (if they seem damaged) and their characteristics.
If the battery voltage is 12 volts and the engine voltage is 12 volts, if the wiring is correct I can assume that the ESC is less volts (the most common ones reach 8.4 volts).
Also for this reason I would like to see a photo.
Geliked door Peejay
Dead short
I have a brushed motor fitted in a caldercraft Imara tug it has a live and neutral that goes to the speed controller and powers from it to the battery running a 12v lead acid battery when its switched. on the speed controller has shorted its been suggested that the fault could be the moto that runs if wired directly so bit at a loss
Stephen james tucker
Geliked door Peejay and Len1 and
Dead short
these speed controller that come from a certain midland supplier I've wire it up ok mid leads to battery outers to motor motor fine but when dead short ideas
Geliked door cenbeth and Peejay and
