clinker-built boat
Gestart door Willem
8 replies 40 vind ik leuks Laatste activiteit: 1 jaar geleden
#9 1
clinker-built boat
modify extended-reach VICEGRIPS to accept your rivet bit tools. You will be able to adjust the tension you need by adjusting the VICEGRIP tension
Geliked door Len1 and Ronald and
#8 1
clinker-built boat
I managed to get a real tight fitting joint with a 4 mm2 copper wire, a 2mm hole and crushing the wire. Wonder if I have to glue as well.
Next to find is a clamp, with a wider range, that allows for broader wooden planks.
#7 1
clinker-built boat
Ross,
sounds like a good idea. I will try this and keep you informed.
It will take some time to find molds to form the rivet heads.
Geliked door hermank and Len1
clinker-built boat
1.6MM copper house wire can be pushed through 9MM of pine, if the end is sharpened to a point.
a hobby hand grinder can be used to flatten the ends, like a rivet. It heats up the wood and doesn't have much holding strength
Geliked door hermank and Ronald and
clinker-built boat
Willem
SLIGHTLY CRAZY IDEA
2 pins required per joint
send a pin through from the outside, trim to size
send SECOND shortened pin from inside right beside first pin
2 heads are better than one
On mine it was simpler. Inside is not open to view. I modified a set of pliers to hold a pin steady. Pushed it in until it came through the inside frame. Pulled it tight from the inside
In yours, push a shortened, second pin from inside, right beside first pin
What diameter head and shaft do you need?
If you are working the rivet close to the edge of the plank, for clinker-built construction, are you concerned about splitting the plank? My planks were 3mm by 10mm and the 0.9 mm nail was in the centre of the 10mm at 5 mm
Geliked door EdW and Ronald and
clinker-built boat
Ross, thanks for your answer.
The pins are a solution, but I plan an open rowboat. The rivets will also be seen from the inside.
In real life, the pins are insertet from outside and on the inside of the hull, the washers are squeezed on the pins to keep the wooden planks together. Then the remainder off the pins are cut and then cropped.
The squeezing is not the point, but how to show the rivets from outside and within the hull is the question. The pictures are from the real thing and these are to big.
Willem
clinker-built boat
Willem
Brass pins and polish (sand after install) the finish off the head.
I used about 900 stainless steel pins in the BLUENOSE hull. It's a lot of work
pin head diameter: 2.1 mm
pin shaft diameter: 0.9 mm
Geliked door Ronald and Len1 and
clinker-built boat
I'm looking for a new project and found a Dutch "haringboot".
This is a clinker-build boot of about 7m long. I plan to build a 1:10 model with a real rowing mate.
Now i'm wondering how to do the clinker-build. The single planks are attached with copper rivets and I want to do the same on the model.
Does anyone know were I can find such smal rivets?
Geliked door tugboatcliff and Ronald and
