Help Please Graupner 2351 Navy Sound Module
Gestart door bruce1946
1 reply 4 vind ik leuks Laatste activiteit: 11 maanden geleden
Guten Morgen Bruce,
Found the manual (in German) on RC Groups site.
First off-
Lead #2 is labelled 'Blitzerausgang' = Flasher output.
Seems to be intended for a flashing light, i.e. police or emergency service boat.
Probably a mini light bulb back then as LEDs were still exotica and expensive.
It has nothing to do with RPM variation of the diesel sound. So not needed unless you want to go flashing😮🙈
Unfortunately there is absolutely no reference to Lead 2 in the manual!🤔
"Should the sound of the RPM speed up when you advance the throttle?"
Yes😉 The module takes it's input for this directly from the terminals of the motor, i.e. voltage being applied via the ESC. So you need a mating connector for lead 3 wired to the motor - brushed only I suspect. Polarity is not important - logical since the motor can run both forward and backward.😉
"adjustment switches" these are actually adjustment potentiometers, variable resistors (known as pots).
Diesel Drehzahl (RPM) - is used to set the diesel sound RPM to your taste when the motor is running full chat on a bench test.
Diesel Lautstarke (volume) - is used to set the max volume of the diesel sound.
Gesamt-lautstarke (total volume) - is used to set the total output volume , i.e. when all available sounds (diesel, horn, ship's bell, wave slap🤔) are in use.
NOTE: there are warnings about setting this too high as it risks damage to loudspeaker and/or the module amplifier. More about that later.
For now; you need a minimum 4Watt loudspeaker.
Have looked at the module specs ... but more tomorrow as it's now 2am here and I'm starting to nod off😴💤💤
https://www.rcgroups.com/forums/thumbgallery.php?t=1771514&do=threadgallery&type=img&group=none&starter=no
Geliked door Rookysailor and bruce1946 and
I have a Graupner 2351 Navy Sound Module in my model Tug. lead number "2: is not connected. Is it needed? Should the sound of the RPM speed up when you advance the throttle?
the adjustment switches are labeled
Diesel drenhzhl ( Speed)
Diesel lautstarke (load)
Gesamt-lautstarke (Overall loud)
lead #2 Blitzin ausgang (speed camera exit) this is not connected to anything. Is this need to give RPM sound increases? where would I find this component?
Geliked door hermank
