Wood glues
Wood glues
Everybody has their own way of doing things, but as my friends here know I test strip EVERYTHING before jumping in with both feet.
Keep us looped in as to how it goes WW.
Wood glues
Here is a picture of my model of HMS Exeter over 1000 deck planks which I glued in place.
John
Wood glues
Have a damp cloth available to stop pva staining the deck when the plank is held in place. I saw a video testing all available pva glues and all the glues worked from cheapest to most expensive, so choose cheap and thick.
However we all have our own way so choose for yourself.
Wood glues
Wood glues
Wood glues
Wood glues
I am devastated that my English led me to confuse glue with varnish. Thank you, Ronald, for your friendly reminder.
🙈🙈 Go stand in the corner . . .ouuuuuu
Good tip, Ronald, about the glues!
Landlubber Michel-C.
Wood glues
Keep a damp cloth close at hand to prevent the glue from penetrating the wood surface wherever you intend to apply a clear finish or stain.
This glue requires careful application, using a brush and lightly applied. Clean off excess glue with the damp cloth.
Some will say they use CA. I have a sensitivity to that type of glue. You can also use contact cement which is applied lightly on both the surfaces, though this glue will not allow much movement after contact with the surfaces.
Wood glues
PS I'm in Canada.
Geliked door
Bezig met laden…
