Steam Glorious Steam.
Volgers (12)
- DuncanPBronze
- NorthernflotsamSilver
- Newby7Bronze
- DWBrinkmanBronze
- chugalone100Silver
- GaryLCSilver
Ian
Ian
Ian
Though the pond police might not like open alcohol on board, especially if he is the skipper.
Pepsi??
Be safe out there!
My steam yacht here started life as a Kingston Moulding hull of the famous 1911 50 foot Steam-Pinnace-199. It lay around for 20(?) years untill I happened to stumble over a neat Chinese steam plant when visiting leading Swiss steam specialist Holzapfel jr. to repair the Stuart-Turner D10 I had dropped. The D10, by the way, is very special. Holzapfel sr. built it in Bronze and I bought it some 50 years ago. With the Microcosm steam plant smiling at me I decided to transform the Whitmarsh hull into a self-designed yacht. Voila, the result. The boat floats as planned, the steam plant works very reliably just like the Denes steam engine control unit and I have even produced a blaze (forgot to lock the nut on the gas tank . . .) but the RC linkages are waiting to be linked (what else . . .?). Some pics will follow as soon as it takes to the water and I will be back then.
By the way, the somewhat dull look of the woodwork is due to the fact that I decided to oil the wood. Much more straightforward than varnish, easy to re-do, sufficiently waterproof (I don't plan to use the boat as a sub) and it still leaves the option of high-glossing some parts, e.g. the cockpit.
Ian
Someone please correct me if I am wrong, but most marine power systems, be they steam from coal or oil, if burning correctly, would emit a grey smoke, and not too much of it, except under severe load conditions. The real except is wood fired boilers which smoke like a banshee.
All that said, the smoke machines currently available commercially as well as those homemade unit do a pretty good job of simulating the real thing.
I would also point out that any unit that smoked "black" would, as Lew has pointed out, make a mess. If you think that dust is hard to removeform your model, you ain't seen nothin' yet.😆
Beautiful model.
Stephen.
Geliked door
Bezig met laden…
