What sort of glue
Gestart door lesfac
4 replies 0 vind ik leuks 0 volgers Laatste activiteit: 12 jaren geleden
What sort of glue
Superglue, without question.
A few days ago I glued some white styrene to brass tube. I later had to remove it, and the styrene tore as I did so. I had to file the superglue to remove it from the brass.
What sort of glue
I use thick superglue, had no problems but dont forget to varnish non glued surfaces first to prevent tarnishing!
Roger
What sort of glue
Same question has recently been asked.
Look under Brass Fittings in the Forum section.
Regards.
What sort of glue
I have made 4 cleats for my Perkasa. I made them In brass and basically the bottom of them Is a 22mm x 8mm rectangle. My Inclination Is to use 2 part epoxy but I am not sure If It will bond metal to the hull permanently.
Can anyone recommend a glue to hold the brass to the painted deck?
Thanks In advance.
Les
