radar motors
Gestart door Vickers1979
8 replies 1 vind ik leuk 0 volgers Laatste activiteit: 11 jaren geleden
radar motors
Speed control units (particularly ones that work off back-emf sensing) tend to be poor at producing low speeds. Brushless motors are a classic example.
PWM controllers can do slow speeds - that's what railway modellers use for shunting - but the motor drive tends to be jerky (which the railway modellers like because it breaks track adhesion)
For radar you want a slow but smooth rotation. For that, gears are the obvious answer, since they suppress jerkiness...
radar motors
rather than a gearbox which will be noisy since its engineering is basic why not just use a direct drive small motor and control its speed electronically?
http://freecircuitdiagram.com/2009/01/02/small-dc-motor-speed-controller/
a simple design which should solve your problem
radar motors
I have just finished making the radar for 12th scale mersey lifeboat using a geared motor from GIZMOSZONE.COM they supply a large range of miniture motors of all different speeds and sizes and are very quiet hope this helps
Geliked door cenbeth
radar motors
HI trillium I got one on the way give it a try it can't be any noisy than the servo I've got in there. Thanks for the heads up.
L s Vickery
radar motors
HI dodgyGeezer just had a look got one on the way will try it out, thanks for your help.
L s Vickery
radar motors
I have one of these ebay motors and think it's noisy. Mine is fastened on the underside of the deck which possibly amplifies it.
radar motors
hI all has anyone got any ideas on motors for a radar, I'm currently using some old servo bit there to noisy, just purchased one from online but it's running to slow would be ok for moving turret or gun, cheers Lee.
L s Vickery
