Graupner Glasgow paddle tug - paddle rotation speed?
Gestart door jgs43
2 replies 1 vind ik leuk 0 volgers Laatste activiteit: 11 jaren geleden
Hi,
according to my experience (the last time with model Lulonga River steamboat) I would recommend a geared motors with the maximum speed of around 150 rpm for Graupner paddle wheels Ø 140 mm.
I use a simple external V Tail mixer - throttle for speed, and mix ailerons for ESC.
I can so with a single stick to control both speed and direction. The rudder for my Lulonga model is inapplicable , as to classical the steamer ,the rudder will surely have better efficacy.
On my first live steamer Ned Kelly(australian type, wheels mounted on a common fixed axis), I had only controlled the rudder, the model was quite handy;rudder but was somewhat larger.On a boating exam, I used substitute wheel from plywood (graupner wheels I got up later).The model was 115 cm long (o.a)
Wishing success
Tom
Main principle: if it is not broken - don't repair It!
Geliked door Inkoust
We used to have such a model in our club and having worked on repairs for the owner I recall that his model had a couple of 500 size low rev high tork motors driving the wheels via a cog and chain system. The paddles do not need to rotate very fast (
I am currently recovering a second hand kit which had been just started by the previous owner. Since the graupner motors are no longer available I need to work out what I require to achieve the correct paddle rotation speed for this model. I can access geared motors and suitable nylon gears etc to effect almost any reduction ratio. My problem is that I require to know what the paddle rotation speed should be so that I can then calculate the various options that might be suitable. Would anyone be able to provide, at least, an estimate of the recommended paddle rotation speed for this boat. I intend using the graupner paddles supplied with the kit as Clyde Model Boats appear to be having problems in obtaining some parts for their excellent alternative units.
