Prop Shaft Grease
Prop Shaft Grease
Prop Shaft Grease
Prop Shaft Grease
I guess I have not run my models long enough yet since I have had no wear in either shafts, bearings or seals. I did have one seal in a Raboesch assembly, in a twin shaft model, which didn't leak but seemed to be deteriorating. Raboesch supplied a replacement free of charge. I had used Goop adhesive to attach the seal/bearing cap so it was a 5 minute job to soften the adhesive with a heat gun and fit the replacement.
Prop Shaft Grease
I agree well made prop shafts such as supplied by Raboesch are excellent.
Personally I make my own to scale and length as I have the materials and lathes with which to fabricate them.
My experience over many years is that over time the bearings and shafts wear and will require replacing at some time. I have used oiling tubes and stuffing boxes for best results, the latter make small leak repairs simple, but if the prop end bearing has worn it needs replacing.
Our last club sailing waters were saline and I had to replace the bearings in all the models I sailed there. I used to wash the model hulls after every sail but it didn't help. I use a thick oil in the tubes.
Prop Shaft Grease
Prop Shaft Grease
Prop Shaft Grease
Prop Shaft Grease
Best way to remove the propshaft is to undo the universal joint at the top then slide the shaft out through the stern tube . Sometimes this may be difficult if the rudder gets in the way.
If you remove the prop there is a good chance you can extract the shaft without too much difficulty but be careful not to bend the shaft.
Referring to the latter it is advisable to remove the rudder but on some occasions I have bent the rudder slightly though there is an element of risk in this as the rudder has to be realigned.
When reassembling the shaft and universal coupling check that after fitting the prop there is adequate clearance between the prop hub and the stern tube and the same with the coupling so the assembly can rotate freely without rubbing against the tube .
Regards Boaty😊
Prop Shaft Grease
I use Dynamite Marine grease both on my fast electric and scale boats.
You can purchase this from Wheelspin Models and you can also buy a grease gun from them as well😋. it is brilliant for whatever boat you own and with the gun you can really lubricate the whole propshaft.
Boaty
Prop Shaft Grease
Light grade marine grease - whilst offering some friction initially soon eases off on the friction (via a quick run-in), whilst offering a good seal. I have ships, patrol boats and submarines and they all have marine grease. I re-grease the prop tubes/shafts once a year for the frequently used models and others once every few years.
I also tried Lithium grease, but it always remains sticky and so does the friction load. in most cases this is great grease except for prop shafts.
Choose what ever you are happy with.
Prop Shaft Grease
Use a mix of silicone, copper slip mixed with a little castrol gtx to make the mix like creamy consistency as found like most of you know that the grease gets thrown to walls of the shafts tube and just sits there not doing anything to lube the shafts
Prop Shaft Grease
I was told to use plumber's tap silicon grease, which I have used for 3 years and only regreased once each year.
I have added oiler/grease tubes to my rudders as well.
Also you can get a silicon spray like WD40, but, with the silicon spray it crawls up the shaft.
With the shaft out and the tube cleaned out(pipe cleaner works well for this) a shot of silicon grease in each end of the tube(only small amount).
Hold your finger over the other end and install the shaft, this stops the grease coming out as the shaft comes through.
A shot of silicon spray down the oiler tube and seal silicon fuel tube sealed off at one end.
Canabus
Prop Shaft Grease
Prop Shaft Grease
Years ago (30+), I used special silicon grease (could get it from work, when it date expired - no I never understood that, but it did mean that I had a ready supply of 'out of date').
Geliked door
Bezig met laden…
