Fire Boat 34" Laser cut Window kits
Terry
Trial run.
Trial run
In my notifications I saw something about dpd carriers £14.45 plus vat ?
If that's right it's much less than I expected.
So if we can round the whole thing off to £100.00 we gotta deal!
Cheers Doug
doug-bell@t-online.de
+49 176 43216081
Cheers Doug (AKA RNinMunich) 😉
PS Country code I gave is wrong! 49 for Germany not 48 🤔
PT Boat
best regards Doug Bell
+48 176 43216081
http://kitshackmodels.com/index.php?route=product/product&product_id=745
slowing your pace when riding through town
Yes that's not a problem we can have some Windows sent to you. £15 would be the cost for these. I hope this would be ok.
Darrell
If you would like to email me personally detailing exactly what your requirements are and I will put a Price together.
My email is (Email Removed - PM Only)
I do understand your scepticism but let me asure you I will get a resolution for you.
KitShack
I am dennisw I have nothing to do with making window frames.
I enquired about frames.but I do not sell any.
dennis sorry.
How long ago was it that you were promised one of our kits, KitShack has gone through a transitional period recently so your messages may of been missed. All our kits are cut on a CNC machine and are cut to order currently and would be happy to provide you with one. We have a website up and running now, you can check this out at www.kitshackmodels.com
KitShack Models
If you still need them or inthe future we should be able to get a set sorted out for you on our CNC cut in 0.8mm ply.
PM me for more info
KitShack
then my laser cutter left where he worked and there hasn't been a direct replacement for him since.
it also meant I had to have a chunk of my own money sitting on the shelf on the off chance that somebody might order a set... not good!
then over-seas customers started ordering kits at the uk price and I was losing money all over the place with excessive postage costs etc.
is it worth the hassle.....? sorry guys... no!
so at the minute I have just got too much other stuff on
David, please could you tell me if,you are still producing the window/frame set,and if so, when do to expect them to be available. many thnks...............
I AM CURRENTLY OUT OF STOCK OF WINDOW KITS FOR THE 34" FIREBOAT.
I will let you know when I have received the next batch from the cutters. please do not order till then
Leslie and Richard your orders are in the post
thankyou
David
still have window kits for the 34" fireboat while stocks last.. if you are mainland UK please use the buy it now paypal button on the listing...
international orders please contact me via private message for postal costs
any problems please send private message or email
thanks
David
Many thanks.
Will.
thanks
David
Thanks very much for the Fire boat windows they look grate.
Regards Chris.
as for window kits for the 46" 1/12 scale boat, not yet! though I do have a 46" boat to restore so "maybe"
how about posting a photo of your boat with the window kit fitted on here.. lets see those windows
thanks
db
Thanks Colin.
many thanks for the windows they look brilliant,
perfect.
remove the blue protective film from the clear window panes(pic 1).
lightly sand round the edge of each pane (both sides) with some 400grit wet and dry paper to remove any burrs left by the laser and to help adhesion to the cabin sides (pic 2).
the white window frames have a matt and a glossy side, make sure you keep them the correct way round with the matt side facing outwards, they can be painted grey if required using acrylic or enamel paint or just left white like the photo's. again lightly sand the gloss side to remove any burrs to aid adhesion.
I stuck the frames to the panes using that really thin brush on adhesive for plastic model kits (pic 3). I stuck the windows to the hull using 5 minute epoxy (pic 4)..
Important (hindsight bit) fully degrease the cabin sides and lightly rub down around the window aperture before glueing (I didnt and the several layers of "Mr sheen" I had used to clean the boat helped the windows to come unstuck!)
overheating... now I had run my boat with open windows with the water cooled speed 600 for ages no problem! first run with the windows fitted and everything was smelling really hot in there! so I have cut two cooling holes in the deck tween forward and aft cabin compartments to let a bit of air in/out which seems to have cured it for now
the four port holes.. I assembled as above then painted the back of the clear pane black and glued them on, so didnt bother drilling holes to look inside at erm... nowt!
hope this helps
happy fire boating
db
at last I can offer these laser cut window kits for the 34" fireboat for sale
made In 0.5mm clear and white plastic, though not scale they do enhance the look of any Aerokits 34" fireboat which generally had "wonky window apertures" each kit contains the frames In white and the window panes In clear and Includes all forward cabin windows, the 8 mid/aft cabin windows (not scale) and the 4 portholes for the forward lower cabin as shown In the photos
the price Is A£15.50 posted mainland UK and I have enabled a paypal "buy It now button", just ensure your name and delivery address are correct on your paypal account before using It.
if you dont have paypal, then please send a private message for details for cheque payment
I have the Initial batch ready now but demand may outstrip supply during the early days so your patience would be appreciated.. I will keep you Informed
thanks
David
Geliked door
Bezig met laden…
