1940 Chris Craft
Volgers (1)
1940 Chris Craft
1940 Chris Craft
1940 Chris Craft
Removed all the motor mounts and drive line.
As I am using a 28mm brushless motor, I realigned the new 4mm drive line and decrease the drive angle.
Made a stronger rudder with a little more depth.
Remaking the engine hatch with two 10mm magnets to hold it down.
Fill in a lot of the frame forward of the motor to add strength.
Canabus
1940 Chris Craft
I have started on a 1949 Chris Craft Runabout as I bought the started kit for a good price.
Drop out all the motor and 1/8" shaft.
Installing a 4mm shaft and a 28mm brushless motor.
As I have all the frame patterns etc. I could easily make the 1940 one as only the rear would require modifying.
Canabus
1940 Chris Craft
They told us, it is on the water most of the year in Seattle. The boat is varnished every two years. It requires continual care as the salt water is corrosive.
Also seen was a nifty outboard; even the outboard motor cover is made of wood.
A group of friends were seen enjoying a dockside luncheon. They said “Please take our picture” Very nice inboard Runabout.
Geliked door
Bezig met laden…
