Fibreglass hull/deck fit
Living in Munich, with a German keyboard, I have to switch between English and German, BUT I switched off the automatic spelling correction so I can check what it's offering for alternatives 😉
I see you are in Eastbourne, do you sail in Princes Park?
Until recently my Mum (93) lived in Royal Parade just round the corner from the park. Sometimes if I drove over from Munich I would take my 1/72 H class destroyer with me and sail it in Princes Park.
Last time there was a guy there with a Trident sub with full diving system.
I played cat and mouse with him, trying to 'be there' when he surfaced, good fun😊 Cheers, Doug 😎
Holding the lot together with wood cramps until good an' hard.
If you get the measurements and cutting right the deck should fit like a glove. That's what we do to get things to fit right in 'Plastic Magic' kit conversions.
That's also the method recommended by Deans Marine for the 1/96 53" HMS Manxman kit I bought from them. Download the build instructions from their site and you'll see exactly what I mean. Most (if not all) FG hulls will tend to sag outwards a bit after curing and release. My Fleetscale 1/72 destroyer hull was just the same.
Good luck whatever you try. I can't believe that it is necessary to cut a deck down the middle. 😲
It helps if you warm the hull in hot water (not boiling or too hot for the hands!😡) to make it more flexible and amenable 😉 while fitting the beams and bulkheads.
Good luck, post some pics of your progress 👍
BTW: What's the model of?? Cheers, Doug😎
Cheers, Martin
That's what I'd do. Ain't nuffink can't be fixed!
Geliked door
Bezig met laden…
