SLA question
Gestart door J Barry
7 replies 7 vind ik leuks 0 volgers Laatste activiteit: 8 jaren geleden
SLA question
Hi J.Barry,
You can use the SLA batteries in any position but if they are laid on their side the weight is not evenly distributed. Most of the weight is in the lower section of the battery (when vertical), so if you lay one sideways in your boat you need to move it so that the weight is even, especially if you put one on the centreline of the boat (say over the keel). You can test this outside of the boat.
Geliked door rcmodelboats and KenThompson and
SLA question
Hi Colin,
Get well soon!
So that you may be able to go sailing.
This coming Summer!
Cheers, Ed
"Fair winds calm Seas"
73
SLA question
New knee is healing slowly, but getting better each time I use it, staples coming out Friday. As soon as I can kneel again I will be back sailing again. Great news about the motor Doug.
SLA question
Exactamente Ed & Colin (How's the k-nee!?)👍👍
BTW; got the brush-gear sorted on your motor, it's running sweetly now 😉
SLA question
Hi J Barry, most of my larger boats use 12v 7ah sla's I have even used them laying flat and as ballast. Never had a problem with them at any angle. Hope this helps you.
Geliked door RNinMunich
SLA question
Hi J.Barry,
I run SLA's in my tugboats!
Yes, you can put them in any position!
They are sealed and there's no liquid in them.
The batteries are sealed electrolyte-tight, immune against installation attitude they are solid!
Cheers, Ed
73
SLA question
I know this must seem a pretty dumb question to many if not most of you, but do SLA’s need to be upright? I have 12v 7ah and it doesn’t quite fit where I would like to install it!
Your thoughts would be appreciated; be kind now.......🤐
Cheers,Barry
