Sailing Barge plans help
Gestart door Joe727
5 replies 2 vind ik leuks 0 volgers Laatste activiteit: 8 jaren geleden
Lemmerhengst, Thank you for the reply, I saw that site and couldn't reach it, thank you for pointing out that they are rebuilding. I'll keep an eye out, looks good.
Joe
Hello Joe,
Try AMBO (google)
They are the association of model barge owners and I believe they are based around Maldon, Essex. A great site that is currently under rebuild (like many 12'' to the foot barges!)
Good luck with your research.
Cheers Lemmerhengst
Geliked door Joe727
Hi Joe,
Just happened to be trolling by the computer when it honked! 😁
Glad it was useful, don't forget the Build Blog 😉
Have fun, Doug 😎
Hello Doug, Thank you for the quick response! I will probably take the hull lines drawing and create the ribs, etc.
Cheers Joe
Hi Joe,
You should be able to find something here.
https://www.google.com/search?client=firefox-b&q=thames+sailing+barge+plans&sa=X&ved=2ahUKEwic8szWkYnfAhVDZVAKHXeMDvAQ1QIoAHoECAQQAQ&biw=1922&bih=953
You might have to do some scaling up though.
Happy Hunting, cheers, Doug 😎
Geliked door Joe727
I have been intrigued with British sailing work craft and built a 45" Gaff Rigged Falmouth Cutter. Now, I want to build a Thames Sailing Barge, are there any free plans out there (tight budget as I am retired), even just the hull plans would be great.
Regards, Joe👍
