"........there isn’t a huge amount of swivel on the buckets, was thinking of putting a mixer in rather than a rudder?, I suppose it’s just trial and error.... ...."
If you put a small 'dagger plate' on the keel, like the power racers do, that will improve the turning no end....
"....There were plans for a noodle boat in a fairly recent model boats mag..."
Several years ago I drafted up an EeZeBilt RIB. This used foam pipe insulation (ready-split!) for the inflatable section, had a standard brushless prop and used a servo hidden in a dummy outboard to swing the outboard for use as a rudder.
I never completed the boat, and did not publish the plans, but if there is some interest I will look at revisiting the idea. Here are a few pics of what the boat was to look like:
[{"id":"155566965199","name":"155566965199.jpg","caption":"","url":"https:\/\/nl.model-boats.com\/media\/155566965199\/l","thumbUrl":"https:\/\/nl.model-boats.com\/media\/155566965199\/s","isImage":true,"ext":"jpg"},{"id":"155566966886","name":"155566966886.jpg","caption":"","url":"https:\/\/nl.model-boats.com\/media\/155566966886\/l","thumbUrl":"https:\/\/nl.model-boats.com\/media\/155566966886\/s","isImage":true,"ext":"jpg"},{"id":"155566969088","name":"155566969088.jpg","caption":"","url":"https:\/\/nl.model-boats.com\/media\/155566969088\/l","thumbUrl":"https:\/\/nl.model-boats.com\/media\/155566969088\/s","isImage":true,"ext":"jpg"},{"id":"155566969949","name":"155566969949.pdf","caption":"","url":"https:\/\/nl.model-boats.com\/media\/155566969949\/l","thumbUrl":"https:\/\/nl.model-boats.com\/media\/155566969949\/s?preview=documents-3","isImage":false,"ext":"pdf"}]
Hi John, yes, there isn’t a huge amount of swivel on the buckets, was thinking of putting a mixer in rather than a rudder?, I suppose it’s just trial and error....
Looks good, you may need a rudder if you have problems turning! I had a similar boat which was fine in straight lines 😁
Happy sailing.
John.
There were plans for a noodle boat in a fairly recent model boats mag ,though not jet propelled,can't find the issue as the wife has "cleaned up my corner"👍it's here somewhere.
I’ve decided to realise a plan I have in my head, I’ve seen a craze for building ‘Noodle Tugs’ based on the swimming aids you find at the pool, and want to see if I can incorporate jet drives :-)
As with most projects start with a sheet of ply and see where it takes you, so I fitted the Noodle, shaped the transom and fitted a couple of jet drives, still lots of detail yet to be thought through but it will either work or it won’t!
[{"id":"155488551536","name":"155488551536.jpeg","caption":"","url":"https:\/\/nl.model-boats.com\/media\/155488551536\/l","thumbUrl":"https:\/\/nl.model-boats.com\/media\/155488551536\/s","isImage":true,"ext":"jpeg"},{"id":"155488551578","name":"155488551578.jpeg","caption":"","url":"https:\/\/nl.model-boats.com\/media\/155488551578\/l","thumbUrl":"https:\/\/nl.model-boats.com\/media\/155488551578\/s","isImage":true,"ext":"jpeg"},{"id":"155488551666","name":"155488551666.jpeg","caption":"","url":"https:\/\/nl.model-boats.com\/media\/155488551666\/l","thumbUrl":"https:\/\/nl.model-boats.com\/media\/155488551666\/s","isImage":true,"ext":"jpeg"},{"id":"155488551782","name":"155488551782.jpeg","caption":"","url":"https:\/\/nl.model-boats.com\/media\/155488551782\/l","thumbUrl":"https:\/\/nl.model-boats.com\/media\/155488551782\/s","isImage":true,"ext":"jpeg"}]
