Musical Christmas Tree Project
Gestart door fireboat
13 replies 29 vind ik leuks Laatste activiteit: 7 jaren geleden
"As for programming a whole house display... although I know I've the technical know-how... it's not something I'd want to do! 🤣"
I'm with you Stephen,👍
Might be OK in the States where the next neighbour might be 20 - 50 clicks away but here in 'sardine' Europe? 👎
First the neighbours are up in arms, dann kommt's Polizei😮
(Na denn na denn! Was ist dann hier los? Ausweis bitte!)
(Now then now then! What's goin' on 'ere?) (Knees bend a la Sgt Dixon!😉)
Gets kinda tedious after a few minutes anyway! 🙄 (An' I hate Techno 🙉)
Keep up the great work Stephen👍
Cheers. Doug 😎
PS Build a boat once in a while! 😀
Geliked door Rookysailor and MouldBuilder
That is ideal to get you started.
It won't be long and you will be doing some fantastic things with it.
Well done.
Geliked door MouldBuilder
The picture mentioned earlier. £20 including a download of 32 projects for the contents.
Peter.
Ebay item number 293289109379 is now £22 from Hong Kong but Item number 264367001650 is just over £25 and is sent from UK.
Geliked door Martin555
Brilliant Stephen. Happy Christmas.
I have recently bought a 32 project starter Arduino kit from ebay for £20. It is incredible value. The programming software is free on their site. It all looks very interesting. I will post a photo of the kit later today.😊
Hi Stephen,
Looking at your code, that is to advanced for me at the moment, but it is extremely well done.
Hi Guys,
If you are interested in Arduino and want to start as a complete beginner then may I suggest that you look at the lessons from Paul Mcwhorter on utube.
There are 35 Lessons and he explains things right from the beginners point of view.
If you purchase a ARDUINO STARTER KIT (from eBay) you can easily follow the experiment with him.
He also teaches you to code and explains how to modify it.
He tells you about the Free to download software that you will need.
There is also a free to download Arduino for Dummies PDF on the Web.(just type in Arduino for Dummies)
Hope this helps.
Geliked door MouldBuilder and Rookysailor
Some screenshots here of the arduino code and the programming software I made.
I've seen the vixen lights software before, but I don't think it works on a mac? Also, part the fun was to make my own sequencing software. It's all HTML5 based and works in the browser. Each block is a draggable div, you can select many or some in one go, copy/paste, change colours, fade in, fade out etc. These are then split into tracks and saved to the database, then exported as function calls off a 50ms timer in the arduino code.
It's an Arduino Mega, simply due to the programming space required and the fact it has more available timers in the chip. Some are used by the MP3 player, so it was important not to mix timers.
Stephen
Geliked door RNinMunich and MouldBuilder and
absolutely fantastic, I whish I could do/understand this system it keeps cropping up in all sorts of projects where do I start? is there a dummies start up kit?🤔
Geliked door Martin555 and RNinMunich
Fantastic work Stephen and a good cause, used to play in my local S.A. band.
Reminded me a little of the ending of Close Encounters of the Third Kind, the lights to synth bit.
Cheers, Peter
Looks good - If you are into this type of things - check out free Vixen Lights software - sequencing software( looks simple but it's powerful software - takes a while to get used to - outputs serial commands to the like of Arduino - software downloads/install often flag as malware etc - they are 100% safe
http://www.vixenlights.com/
Great use of RGB addressable LEDS
And then you can do this
I think it's the way I have learnt most of my stuff - getting very stuck first...
Hi Stephen.
!!!ABSOLUTELY AWESOME!!!
You'r timing is spot on.
I just had to watch the other videos on utube.
I tinker a little with Arduino but nothing as spectacular as that.
What Arduino board did you use ?
I would love to see a little of the code.
You have inspired me to do more with the Arduino.
Absolooootly brilliant Stephen😮👍👍👍
Have a great Christmas,🎁🎈
Been busy building something a bit different recently. Thought I'd share with you all, merely from an engineering point of view some of you might be interested!
We have a competition in work, for best Christmas display. Normally people just hang some tinsel here and there, but I took it a little more seriously... put my Arduino coding skills to use and made a whole Christmas tree, choreographed to music.
Raising a little money for charity by doing it.
https://JustGiving.com/UnileverTree
Taken 6 months to make in my spare time, started back in June! Most of the ornaments I already had, but they needed cutting in half and the old lighting stripping out of them. The whole lot uses addressable LED's, so technically only 3 wires throughout (12v, GND & Signal). Birds nest is literally sticks from the forest hot glued together. Same with the logs. The forest floor is sand I had spare from putting a patio down last summer, again glued down. Tree's and little cars are from home bargains. The street lights, traffic lights and logo was all 3D printed. Then roads, roundabouts etc simply painted.
Software is relatively simple, but to get all the timings right I did have to make some desktop software that let me edit light effects in a time line, then export it all as Arduino code to load in. The Arduino has an MP3 breakout board attached, so any music can be loaded and played.
5 tracks in total on a loop, about 15 minutes worth. I'd like to have programmed 12 tracks, but ran out of time, maybe next year! There are also ribbon blowers at the top via drain pipes which I 3D printed centrifugal fans for. They work, but a little noisy so again something for next year!
Hope you all enjoy too!
Stephen
Geliked door MouldBuilder and robbob and
