Grease
Gestart door mturpin013
6 replies 5 vind ik leuks Laatste activiteit: 7 jaren geleden
Grease
Non float grease pops into mind, but I don't know where you get it from nowadays
Grease
I use two types of lubricant.
The picture on the right is by Silver Hook.You can find it on EBay for about £5.00.
The other picture shows a waterproof grease which I mix two parts to one with some light oil from the bottle which was originally used for my Mum’s sowing machine.
Both options work well.
Bill👍
Geliked door Martin555
Grease
Hi Guys,
I use normal multi purpose grease and thin it a little with 3 in 1 oil.
I mix in just enough oil so that it softens it a little then squeeze it in using a syringe.
It also makes it a little easer to clean out and replace.
Grease
I would personally use grease. My opinion is that it would perform better at the rpm our motors rotate at. It would also stay in place in the bearing at all times, I think.😊
Grease
Have tried both in brushed and brushless motor indtastions. The shafts have always been plain SS running in brass tubes.
Prefer oil, the grease seems to solidify and drag, whilst the oil just slowly emulsifies with the slight water ingress.
Must add, always fit shaft oilers and oil prior to each days use. The shafts are removed and cleaned every season. Have never noted any wear bands.
Am interested in other opinions but oil (regular light engine grade) works best for me.
Grease
We are getting ready for the maiden voyage in summer so need to look at lubricating the prop shaft (4mm shaft). It has a sealed ball race at the motor end and phosphor bronze or maybe only brass at the other end so whats the recommendation, oil or grease?
Geliked door Scratchbuilder and Martin555
