Photos to Paper Mock-Up
Gestart door Ronald
26 replies 52 vind ik leuks Laatste activiteit: 7 jaren geleden
Hi Ron,
Ref:- "Maybe I should change the subject title"
You could move this to the build blogs section.
Looking good, well done.
Geliked door MouldBuilder and Ronald
#26
Maybe I should change the subject title...here is where the project is at right now. Mounting the rudder getting the alignment correct for smooth operation.
Geliked door redpmg and Martin555
Getting on really well Ron - Where did you eventually get the lead sheetingfrom?
Geliked door peterd
Think you've made an excellent job in a very short time. You must be very pleased with what you have done. Looks as if she will need a fair amount of ballast both internal and external.
Cheers, Nerys
Geliked door Martin555 and Ronald
After clearing our recent snow over the last two days, I take a nap. Then gotta have something more to busy myself..😉
Geliked door peterd
Hi Ron,
She has come on a long way you certainly don't hang about.
Well done.
Totally planked now, and sanding filler applied. Sanding has been done and transom has been made and attached.
Geliked door jbkiwi and jugge and
Bulkheads done. I have seen many of you glue up your hull in diagonal planking as I am planning to do as seen here. No rabbet but instead I glued 1/4” curved sections between the bulkheads which will allow me to securely glue the strips from keel at a 45deg angle and secure to the sheer.
Geliked door jbkiwi and peterd and
Getting along like a house on fire Ron - when you start something you really do move along while the rest of us are still thinking about it .....
Looking good so far.
Geliked door Ronald and peterd and
Yes Martin. The bulkheads are marked for cutting out the centres. In these photos I am aligning the supports with the keel, then glueing the supports but not the keel or bulkheads. Much work to do on the keel before securing. Thanks. RB
Geliked door Martin555 and redpmg
Hi ron,
Is she going to be radio controlled ?
This is harder than anything I have tried thus far, but I think it is coming. Three more bulkheads up front to do yet, and #5 needs to be redone.
Geliked door marky and redpmg and
"I thought it was planked all the way down to the keel bottom."
On the boat in the photo it was Martin, with a big slug of (rusty) iron at the very bottom.
But the bulkheads only went down to what I have now learned is a line with long bendy ears and a short fluffy tail!😂🤣
(Admiral's been round the pink gin again🙄)
Geliked door redpmg and marky and
Don't want to 'rabbet on'😉 so I'll just say
Good post Ron, some very useful info there👍
Especially for complete yacht novices like me.
KUTGW. Cheers, Doug 😎
I see now Ron,
Sorry my mistake, Wrong again As usual.
Confucius he say 'Looks good to me' 👍😉
Nice one Ron👍
Hi Ron,
I know nothing about sailboats but if this is the hull of the boat that was posted then deleted, then i thought that bulkheads (from bow 2 to 8) should continue down to the keel.
I am probably wrong. As usual !!
After drawing up on AutocadLt, the model was plotted at 1-1/2”= 1’ making the model 25” . Here is a paper mock-up half hull to see if the drawing was accurate. All seems to be good on paper.
Geliked door RNinMunich and jbkiwi and
