Best way to hold small parts?
Volgers (1)
At least with cross over tweezers it is a more constant pressure.
That works up to a point Martin.
It can be very hard to release the part without wiggling it sometimes.
Depending on how much the part stretches the rubber.
I tried it with silicon sleeving (look in the Missusseses iron😊) works a bit better as the silicon gives more on release. Heat shrink is very stiff☹️
I prefer the 'cross over' tweezers (don't forget the Town & Country tires😁) though - instant release👍
Maybe what you need are these, reverse action tweezers-
https://www.amazon.com/Testors-8942T-Reverse-Action-Tweezers/dp/B003ZD1148
As usual, and you can see in the link, there are various versions at various prices!
I posted this in the hints and tips section.
My solution is to use a couple of pieces of rubber insulation from electrical wire or some heat shrink tubing.
Just pop it over the tips of said tools, this will give a little more grip with out damaging the piece and stops it from pinging out.
Hope this helps.
Geliked door
Bezig met laden…
