Billings Boats Sea King
Volgers (5)
- RookysailorSilver
- Newby7Bronze
That's what they used on Marquetry in the old days
Try Hobbies limited or Axminster tools
Joe
Cheers, Pete
On another note, what is the best way to cut the thin veneer? A scroll saw seems to be a poor choice.
being Billings, it should be good quality wood, it certainly looks that way, nice lines on the hull, you will have fun making this I'm sure.😊
Cheers, Pete
Rick
No not really,
You should do whatever makes you happy.
As you know i try to make my HMS Cottesmore true to original.
U552 is being made as i want it so she is not original.
But i also make strange things or boats that only exist in my head.
It keeps me happy and that is the main thing.
Oh dear. I do not think I am capable of making a model true to the original. I am going to put two motors, rudders and shafts into my 46" Crash Tender build just to be different. My Dusseldorf is going to be red. (I just could not find the correct colour. Am I bad?
"why twin screws and a single rudder?"
Why not if that is true to the original!
That set up was common on many ships and fast boats. Even navy destroyers, until in the 30s the German navy started a class of destroyers with twin shafts AND twin rudders.
They proved to be more manoeuvrable than a single rudder.
With a single rudder the jury is still out as to whether the props should turn outward or inward when going ahead (seen from astern).
Many years ago a retired RN captain told me to change my destroyer to inward turning to improve the rudder effect. I did and it did!😊
Main reason for the two shafts I guess was that two smaller engines were cheaper and easier to build in than one massive engine, and propeller😮, to provide the same 'shove' and performance. Was also safer. If one drive line fails you can get home on one.😉
Same applies to our models - e.g. if one prop gets jammed by weeds etc.
A larger prop would have it own problems, not least increasing the ship's draught.
PS Can you post some pics of the kit please? There's no data on the Billing site anymore🤔
Geliked door
Bezig met laden…
