motor
Gestart door brianupyonder
3 replies 4 vind ik leuks 0 volgers Laatste activiteit: 6 jaren geleden
motor
Hi Brian, A lot depends on what performance you are looking for and what water you will be sailing on. If you are looking for a reasonable performance with a low cost try the MFA 385, a well made motor which can be fixed using the supplied mounting plate or, without the plate, fixed by the two normal mounting holes. Higher performance using a brushless motor can be achieved but what good if you are using a small pond. On a larger pond then the greater power and speed can be more easily observed and appreciated. Geoff L.
Geoff L.
Geliked door jacko
motor
hi everyone
im after advice again,what size electric motor would you fit in a patrol boat 20 inch length
6 inch beam
all help appreciated
cheers brian
brian
