balsa
balsa
I retired from David Brown Santasalo in South Africa a couple of years ago. Part of the holding group (Clyde) also owned Moventas as they had bought the group from Metso. Moventas and Santasalo operated up until about six years ago independently. Clyde in their wisdom took all wind turbines from DB and Moventas and formed Moventas.
Seen these things up close.
Balsa is very strong compared to weight.
As for the bottle coks not sure about that In SA. Most wines have screwtop closures now. This is due a world shortage of Bark.
Lets hope we can get balsa from somewhere.
balsa
Nerys
balsa
Apologies. No offence I hope, The comment is a generalization as to the way boats were designed and built and the old stuff used balsa for the reason stated.
Today we have liteply and even flexible ply!
I have only seen the flexiply on displays. I cant afford a huge sheet😊😊
balsa
I think it comes from the old days as balsa has a good strength to weight ratio, in the 60's and 70's Bringing the mass of the structure down was to ensure that the hull was light enough to get the motor, lead acid battery and radio in.
A boat the size of a Sea Queen at 46" is still today built from ply and it needed a Lead Acid Battery for the ballast! Try dropping an old fashioned set up into a 26" hull.
balsa
Cheers, Nerys
balsa
Nerys
balsa
Geliked door
Bezig met laden…
