Masking Tape too strong or clumsy - simple solution
Volgers (5)
- CashrcGold
- mturpin013Bronze
I have found another excellent masking tape that doesn't leave the glue residue. It is made by Sellotape and it is red in colour and made of plastic apparently made for the professional
Cash
Same with Tamiya tape Mike👍
I use it to mask the edges, then cover the rest with a fine decorators 'crepe' masking tape and newspaper.
The 'creepy' tape is only stuck to the Tamiya tape😀
hope this helps
brian👍
That sounds an interesting way of masking.
I suppose you could past the strips of paper first then apply to the object to be painted ?
So I made up a paste of flour and water. Just an eggcup of paste, like single cream.
They I brushed this onto the model. Using old newspaper strips I created my own masking tape and put it onto the wet paste.
If I need masking on a detail such as a dashboard switch (very tiny) I simply pained some paste over it.
Then I sprayed paint or lacquer.
The following morning I popped my model in the bath with water and left it floating. 10 minutes later the newspaper had fallen off, paste had dissolved and the model was gleaming.
Geliked door
Bezig met laden…
