Gannet 15CC 4 stroke engine
Excellent result.
I bet you are a happy bunny.
I am not sure but it looks like the shaft screws in to the black hex/rubber/hex coupler.
It may be a case of undoing the locknut at the prop end and releasing the motor before you can undo the locknut at the coupler end.
Or undo the locknut at the coupler end and turn the shaft to undo it at the prop end.
As I am a Mechanical Engineer by trade I can inform you that Multigrade oils are better than monograde. You would have no problem using a modern oil in an old engine my 1967 Mini Cooper S runs on Castrol GTX
www.modelenginenews.org/cardfile/gan_chinn.html
I knew Peter Chinn in the 60's when I lived in North Norfolk, he was at Cromer and wrote regular engine reviews for Aeromodeller. Vey nice chap and always friendly. He sometimes joined us at North Norfolk Aeromodellers .
Best of luck with your project
Geoff
This is my first post so thought i would start with a tough one. I have recently purchased an RC boat ( not my first large Petrol boat) that is powered by a Gannet 15CC 4 stroke petrol engine. The engine is in good condition even the points and is correctly installed with all accompanying ancillaries. Does anyone have any information on these engines or operational manual ? I have tried google but have drawn a blank so far. From some youtube videos i think it needs SAE 30 oil and definitely leaded petrol.
Any info appreciated
Geliked door
Bezig met laden…
